How does this motor look?
Old May 18, 2016 | 06:02 PM
bcintron95's Avatar
Default How does this motor look?
Title says it all. Thanks in advance
Are these super tech valve springs?
Gsr head and block
Old May 18, 2016 | 08:50 PM
motoxxxman's Avatar
Default Re: How does this motor look?
it looks like a motor, that i can assure you.
I hate cheap block guards, they usually cause more harm than good.
head is built. I see bronze valve guides, possibly supertech. bronze guides work great, but dont last long. retainers and springs are aftermarket too, though theres no way to tell what brand. head is ported too, but also no way to know how much its been ported. you'll definitely want to get the intake manifold port matched to the head.
pistons are new, though I can't read the numbers on them to identify them. block is clean, deck surface is very clean bit is not freshly shaved.
please get timing covers.
ditch that rubber vacuum cap on the water pipe, it WILL dry rot and pop. replace it with a cap of some sort that is designed specifically for cooling systems.
the rtv on the intake flange deeply concerns me. that tells me the assembler was a moron, and I'd be skeptical about the entire motor based on just that one thing.
Old May 20, 2016 | 09:06 PM
PyroProblem's Avatar
Ditto. Hondabond on the intake gaskets is not a great sign. That and the crank pulley looks like the engine has been dropped. Valve cover paint job makes me think it wasn't built by someone who is particular to details.
I'd always be weary of buying an engine someone else "built".
Old May 20, 2016 | 09:09 PM
Cam lobes look good though. No unusual wear patterns that I see. ☺
Old May 21, 2016 | 09:22 PM
bcintron95's Avatar
Thanks for the input guys! So I looked at the motor and there were some "questionable" things
1. Some oil build up on 2 of the intake valves. Here are some pics
Clean and closed
Guides had oil all over them. Also valve was open
Another pic of cylinder above
Clean and closed
Clean and closed
What's up with the white stuff?
2. I'm not sure the order of how the valves should open but I would think it would be similar to the way the Pistons fire (1&4 and 2&3 the same). Well the valves weren't like that. Seemed like 2 would open a little then 3 would open.
Needless to say I didn't buy the motor. Would like to know what's up with this though. Thanks ahead of time
Old May 21, 2016 | 09:29 PM
bcintron95's Avatar
Link to a vid I took showing the valves better
Old May 22, 2016 | 11:11 AM
The oil on the valves is probably just leaking valve stem seals.
The white hard stuff is basically burnt oil (carbon compounds) but it gets super hot enough and turns it white.
Old May 22, 2016 | 11:13 AM
The open/closed valves are purely dictated by the cams and what stroke the cylinder is on (intake/compression/power/exhaust). In other words, it's normal.
Old May 22, 2016 | 11:30 AM
bcintron95's Avatar
Ok thanks for the clarification. So the burning oil would it be coming from the seals then since its on the stems or would it be coming from the rings? Dude said he broke the motor in with the turbo on (big no no from what I heard).
It's a b18c1 with 1500 miles it shouldn't be burning oil in the first place lol my gsr has an unknown amount of miles and I don't have white **** on my exhaust valves
Old May 22, 2016 | 11:38 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Moved to the misc/tech section as this thread doesn't really apply to precision machine work or precision engine assembly.
This is more of an engine "appearance" thread.
Old May 22, 2016 | 11:57 AM
I agree, it shouldn't be lol.
I have never came across a written or published way to check or test for leaking valve stem seals.
Breaking an engine in with a turbo may not be necessarily bad as long as it was done correctly. There are a bunch of things that can contribute to oil consumption even more on a turbocharged setup. Even small things like ring end gaps and piston to wall clearance can affect oil consumption.
Old May 23, 2016 | 08:12 PM
Turbo-VTEC's Avatar
I'd pass on that
Old May 24, 2016 | 02:16 PM
bcintron95's Avatar
Originally Posted by Turbo-VTEC
I'd pass on that
Yeah I did the same. The whole white on the exhaust valves really messed with me. then when i went to compare my motor to that i just knew something was up.
Old May 24, 2016 | 02:18 PM
bcintron95's Avatar
Yeah. the dude was into Toyotas, so Im sure is builder is a Toyota guy and those things probably where over looked.
thanks for the help man.
Old May 25, 2016 | 06:14 AM
Bull Steed's Avatar
Never got the compression numbers off of it? (Tested?) That would be the ultimate on how an engine "looks," IMHO.
Old May 25, 2016 | 01:36 PM
bcintron95's Avatar
You are 100% correct. According to the dude, someone drove the car and fell in love with the motor. He put a 200$ down payment and they pulled it but the dude backout due to lack of funds. So no compression #
aznkr4zyboi
Jul 24, 2008 01:08 AM
Reza^
101
Oct 27, 2007 08:03 AM
Willard
Sep 13, 2003 10:41 PM
1985 civic
Feb 20, 2003 10:05 AM
