How do you tell difference between starter going & igniter going out???????
Old Jan 17, 2002 | 11:22 AM
714eg's Avatar
Default How do you tell difference between starter going & igniter going out???????
I have people telling me it's your starter then it's no your igniters going out. How in the heck can you tell the difference? Starter usually will click when you try to start right?
Old Jan 17, 2002 | 12:06 PM
earl's Avatar
Default Re: How do you tell difference between starter going & igniter going out??????? (Teamvizine)
If the motor is spinning over like crazy, it's not your starter. If there is no spark at your plug wires, it could be an igniter.
Old Jan 17, 2002 | 12:12 PM
714eg's Avatar
Default Re: How do you tell difference between starter going & igniter going out??????? (earl)
when i try to start the car the starter makes no noise @ all.
Old Jan 17, 2002 | 12:29 PM
earl's Avatar
Do your head lites come on strong? If not, it's the battery. Also check all your grounds (frame to motor etc.) Can you push start the car (must be a stick, of course)?
Old Jan 17, 2002 | 12:40 PM
714eg's Avatar
All of my accessories come on. But when it doesn't start i let it sit and then try starting and then all of sudden it will start.
Old Jan 17, 2002 | 12:42 PM
sol-man's Avatar
Alternator?
Old Jan 17, 2002 | 12:44 PM
714eg's Avatar
Default Re: How do you tell difference between starter going & igniter going out??????? (sol-man)
It's not the alternator it's has a brand new alt.
Old Jan 17, 2002 | 12:51 PM
Jason kiDD's Avatar
Its the ignitor. Just check the wiring to make sure its not loose or anything. When it gets real bad though the car will start to just shut off when you are in motion..
JPerkMr954
Jun 9, 2013 08:51 PM
DriveSlowHomie
Jan 26, 2010 10:31 PM
skn181
Mar 23, 2007 06:02 PM
Fatboy1985
Dec 26, 2003 02:38 AM
RCautoworks
Jan 17, 2003 10:19 PM
