How do these plugs look?
Old Jul 14, 2007 | 09:56 AM
bacid's Avatar
Default How do these plugs look?
From looking at the NGK pic chart i *THINK* that engine is OK but might be running a little rich (due to the black soot on the ring).
Pics of the plugs are here:
http://www.mrchan.net/IMG_1308.JPG
http://www.mrchan.net/IMG_1309.JPG
Am I correct?
Old Jul 14, 2007 | 12:59 PM
4g hatch's Avatar
whats your setup. is it stock or modified,is it tuned or not
Old Jul 14, 2007 | 10:02 PM
slowcivic2k's Avatar
Default Re: How do these plugs look? (bacid)
Black soot on the ring appears on almost every plug.
Timing looks good. The plugs look cold, because there are no heat rings on the threads, normally the first 2-3 threads on the plug will discolor, indicating normal heat range.
Are those soot marks on the insulator permanent, or can you wipe it off?
They look pretty good, but I would get a warmer plug, what engine do you have?
Old Jul 14, 2007 | 10:30 PM
bacid's Avatar
i have the 4cyl 2.3L accord engine, F23
car is bone stock, a bit over 150K on it.
soot marks on the insulator can be wiped off.
Old Jul 14, 2007 | 10:36 PM
Default Re: (bacid)
The engine is in good shape, a little bit of extra fuel, air filter might be old, but given the mileage, it doesn't look bad at all.
Old Jul 15, 2007 | 01:08 PM
4g hatch's Avatar
i wouldnt worry. just run it
Old Jul 15, 2007 | 01:31 PM
DecentCivicZ6's Avatar
B A N N E D
yeah its a DD car, any DD car that stays at low rpm will have some black.
denierlexiese
Aug 31, 2015 03:08 PM
Lightsped
Sep 2, 2009 04:24 PM
crxsirvtec
Apr 11, 2009 09:29 AM
Floyd
Jun 18, 2002 01:35 AM
