How do i remove the sticky stuff in the door panel?
Old Apr 18, 2004 | 07:52 PM
93FastLs's Avatar
Default How do i remove the sticky stuff in the door panel?
i took off my door panels, and i was trying to take off that grey sticky glue stuff..that holds that plastic sheet on..any ideas on how to take it off.
Old Apr 18, 2004 | 07:58 PM
atc5's Avatar
Default Re: How do i remove the sticky stuff in the door panel? (93FastLs)
pick at it, razor blade, and/or this stuff called goof off. I just peeled mine off today.
Old Apr 18, 2004 | 10:01 PM
TIRENECK's Avatar
Default Re: How do i remove the sticky stuff in the door panel? (atc5)
dam this is the dumbest question i ever seen, its just like asking how to pick ur nose.
Old Apr 19, 2004 | 12:07 AM
ejprimo's Avatar
Default Re: How do i remove the sticky stuff in the door panel? (TIRENECK)
you rip what you can with your fingers, then you make a little ball of that **** and use that to pick up any left over sticky stuff. just keep pressing and pulling off the sticky ball against the door until its all comes off.
Old Apr 19, 2004 | 12:13 AM
SleepyHF's Avatar
Default Re: How do i remove the sticky stuff in the door panel? (ejprimo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atc5 &raquo;</TD></TR><TR><TD CLASS="quote">pick at it, razor blade, and/or this stuff called goof off. I just peeled mine off today.</TD></TR></TABLE>
Use a blade as he discribed, then you have the annoying small peices. Use lacor thinner for those it will rub off
Old Apr 19, 2004 | 12:26 AM
AspectIndustries's Avatar
Default Re: How do i remove the sticky stuff in the door panel? (SleepyHF)
I heard GAS works fine too.
-=P wells, try going to Autozone, and finding "GOOGONE" That thing works wonder! Safe on paint too..
Old Apr 19, 2004 | 05:24 AM
civic-4-ges's Avatar
Default Re: How do i remove the sticky stuff in the door panel? (synik)
Brake Cleaner, steel ink remover....
Old Apr 19, 2004 | 05:34 PM
93FastLs's Avatar
hold up..! how is it a dumb questions.. i'v been trying to take it off with a razor blade..and my fingers..it's doesnt come off! tried rubbing it off.. i just never knew what kind of solvent to use..! damn..
Old Apr 19, 2004 | 10:02 PM
turbohondask's Avatar
try adhevisve remover it is a little expensive 8 dollars a can but does the job
Old Apr 29, 2004 | 10:26 PM
jdmcivicferio's Avatar
Default Re: How do i remove the sticky stuff in the door panel? (turbohondask)
WD40
civiccpedx
17
Oct 24, 2004 10:01 PM
DC2 to AP2
Mar 10, 2004 07:00 AM
94blackhatch
11
Dec 21, 2003 09:24 AM
bemathew
Sep 16, 2001 09:01 AM
