How do I know if the distributor is bad?
Old Feb 18, 2003 | 06:28 PM
Unknwn_1's Avatar
Default How do I know if the distributor is bad?
Ok, There are four parts within a distributor
1. Ignition Coil
2. Igniter
3. Rotor
4. Cap
But geez, what else is wrong? I have no spark at all. I tried with the plug #1 with a screwdriver sticking it to see if there are any sparks. Know what I mean??
Any sugguestions are welcome!
[Modified by Unknwn_1, 9:38 PM 2/18/2003]
Old Feb 18, 2003 | 09:45 PM
InspiredRacer's Avatar
Default Re: How do I know if the distributor is bad? (Unknwn_1)
Check cap and rotor for excessive wear. Might as well replace them.
Lay the spark plug wire on the valve cover and look for a spark. Try the coil first, then the ignitor. I have both sitting here if you need one. The coil is not bad, except the ignitor is an expensive piece.
[Modified by InspiredRacer, 1:46 AM 2/19/2003]
Old Feb 19, 2003 | 03:38 AM
Unknwn_1's Avatar
Default Re: How do I know if the distributor is bad? (InspiredRacer)
cap, coil, and rotor are new. i got a used igniter replaced already. hmmm, i am not sure what else I can try.
Old Feb 21, 2003 | 07:11 AM
JimBlake's Avatar
After you've done all that, the distributor only has a shaft bushing, seals, mechanical junk.
But maybe you should be looking elsewhere? How do you know the wiring back to your ecu is good? Helms book has a troubleshooting chart you could go thru.
Old Feb 21, 2003 | 07:37 AM
Unknwn_1's Avatar
Default Re: How do I know if the distributor is bad? (JimBlake)
I found out the problem. I noticed the shaft on the distributor wasn't spinning after many crank. To make a story short, it was a timing belt.
Old Feb 21, 2003 | 08:37 AM
JimBlake's Avatar
OUCH!!
Bent valves?
Old Feb 21, 2003 | 08:56 AM
Unknwn_1's Avatar
The owner said he was at a stop light before it die out. Do you guys think they are still fine?
[Modified by Unknwn_1, 11:58 AM 2/21/2003]
Old Feb 21, 2003 | 09:31 AM
Quik Chris's Avatar
leak-down test time.
FYI for future knowledge, when the distributor goes bad, the bering inside puts this reddish brown dust all over the inside of the cap.
Old Feb 21, 2003 | 03:10 PM
Unknwn_1's Avatar
Default Re: How do I know if the distributor is bad? (Shiroi Hakucho)
Thanks!
88 honda prelude
Jul 28, 2007 05:50 AM
94-integra-ls
Feb 26, 2006 06:46 PM
pdc125
May 15, 2005 02:26 AM
duckming
Jun 5, 2003 05:17 PM
dlric
Dec 13, 2001 03:55 AM
