How do I check OBD1 ECU codes on OBD0 car?
Old Apr 5, 2003 | 05:35 PM
Hondasaurs's Avatar
Default How do I check OBD1 ECU codes on OBD0 car?
My car is converted from OBD0-OBD1. On the OBD0 the ECU has a LED. Is there a way to check the codes once you modify the ECU harness to OBD1?
Old Apr 5, 2003 | 06:15 PM
Jeff C's Avatar
Default Re: How do I check OBD1 ECU codes on OBD0 car? (ZC_CRX)
There should be a wire (#8, orange in the first pic) on your harness located in the "D" plug (you can see its location in the first pic). That needs to be grounded in order to and it will make your "check engine" light flash the code, just like to ole LED on the obd0 ecu.
This is what I did. I ran that wire (#8 in my pic) to one side of a 2 prong plug(green in my 2nd pic), then the other wire (blue in my 2nd pic) form that plug needs to go to a ground. Now this will be an open connection and will not make your check engine light flash yet. Next, I take a solderless connector and put it into my plug (see 2nd pic) and this will close that connection, grounding my #8 wire and making my check engine light flash.
Clear as mud?
Old Apr 5, 2003 | 06:43 PM
raene's Avatar
Do you have a conversion harness? On my brother's old (converted to) OBDI CRX, we used to jump the timing adjustment connector on the lefthand side of the car in front of the shock tower. The codes would then flash through the Check Engine light in the gauge cluster.
Old Apr 5, 2003 | 07:05 PM
Hondasaurs's Avatar
Default Re: How do I check OBD1 ECU codes on OBD0 car? (raene)
No. I hard wired it into my wire harness. I wired the ECU right to the distributer and fuel injectors.
Thanks for the info guys!
Old Apr 5, 2003 | 07:57 PM
smokey2.0's Avatar
that's what i used to check mine, but in my car i only get a CEL after 5 minutes of driving.
Old Apr 25, 2003 | 09:12 AM
Kataku2K3's Avatar
Default Re: How do I check OBD1 ECU codes on OBD0 car? (smokey2.0)
Posted in your other post... All you gotta do is ground the OBD1 point D4...
Old Apr 25, 2003 | 09:28 AM
psi420's Avatar
Default Re: How do I check OBD1 ECU codes on OBD0 car? (Kataku2K3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">Posted in your other post... All you gotta do is ground the OBD1 point D4... </TD></TR></TABLE>
lgoodgrace
Apr 27, 2015 03:43 PM
suburban_ninja
Oct 31, 2013 11:21 AM
akurtzer57
Engine Management and Tuning
Aug 2, 2010 01:20 PM
prettylew
Apr 19, 2008 08:27 AM
Hondasaurs
Apr 25, 2003 09:00 AM
