How to disassemble OBD2A distributor?
Old Jun 17, 2007 | 04:18 PM
Aquafina's Avatar
Default How to disassemble OBD2A distributor?
OBD2A distributor from a 96 Civic, D16Y7 (same as Y8).
Have all the top screws taken out from the tray or whatever that the sensors sit on, all top sensors unscrewed. How do I get it apart from here? There are no more screws I can remove.
Old Jun 17, 2007 | 04:48 PM
Aquafina's Avatar
It's a TEC BTW.
Old Jun 17, 2007 | 08:20 PM
93turbo16's Avatar
Default Re: (Aquafina)
Maybe this is late.. but pop the retainer clip that holds a pin through the key way that goes into the cam. Push the pin out.
Then pull the top tray you described up. Then after you pull the top section out just dangled it over the edge of the housing. Then there are two other sensors down there that you have to unscrew. 4 screws, 2 for each sensor. Then pull the whole thing out in one piece.
Wish I had some pics.
Old Jun 17, 2007 | 09:11 PM
Aquafina's Avatar
Default Re: (93turbo16)
Got two of the screws for the bottom two sensors out, just didn't know about the other part.
Thanks.
supermotothud
Dec 8, 2008 11:47 PM
silent-chris
Dec 18, 2004 11:45 AM
benmasters
Dec 4, 2004 05:42 AM
Jaesung
Mar 7, 2004 05:56 PM
vtec.dc2
Aug 24, 2002 11:51 AM
