question about distributor rotor install.
Old Mar 7, 2004 | 03:41 PM
Jaesung's Avatar
Default question about distributor rotor install.
how do i take the leak cover off to get the rotor off?
anyone?
Modified by Jaesung at 5:32 PM 3/7/2004
Old Mar 7, 2004 | 04:38 PM
IN VTEC's Avatar
Default Re: question about distributor rotor install. (Jaesung)
It comes off after you remove the rotor. Rotate the rotor until you can see the screw head in the access valley towards the back of the distributor.
Old Mar 7, 2004 | 04:55 PM
Jaesung's Avatar
Default Re: question about distributor rotor install. (IN VTEC)
thanks so much. I appreciate the fast response. going to get to work. peace
LOVE IN CHRIST
just came back, without the battery terminal connected can i manually turn the rotor? i don't think i can.
Old Mar 7, 2004 | 05:49 PM
IN VTEC's Avatar
Gotta either remove the distributor or turn the engine by the crank pulley bolt.
I usually opt for remove the distributor b/c sometimes I need to use an impact driver to break the rotor screw loose otherwise I risk stripping the head.
Just make sure you note the distributor key/keyway orientation when you remove the distributor if the key/keyway aren't symmetrical. If you get confused, set the cams to TDC #1 and align the distributor to fire at the #1 cap position. That'll ensure that you don't mess up the cam angle sensor phasing.
Old Mar 7, 2004 | 05:56 PM
vtekstorm's Avatar
connect the battery back. with the cap off just crank the motor a lil bit wit the key from inside the car so the screw is facing up
CBR
Dec 22, 2014 04:52 PM
SIRIUS VTEC
Nov 16, 2010 12:13 PM
LoseRPunKx182
Jan 19, 2006 02:01 PM
DCtwoR
Aug 8, 2002 01:34 PM
D-SPEED
Apr 10, 2002 02:41 PM
