How to bleed ABS modulator pump??
Old Dec 17, 2007 | 12:41 AM
atmo_monster's Avatar
Default How to bleed ABS modulator pump??
Help plss.... i did use the search button but didnt show up anything...
so i just posted it up here for some helps from the expert...
Yeah the car is honda inspire UA2, its got leaking on the pump modulator, so the ABS check lite keeps going on...
and now i have to replace it, but just wondering how to bleed it..
thanks
Old Dec 17, 2007 | 12:16 PM
Perfectionist's Avatar
Default Re: How to bleed ABS modulator pump?? (atmo_monster)
As far as I know, it's a pass through system and the normal sequence and routine for bleeding the system at all 4 wheels should apply. Check out http://www.tegger.com for more information.
Old Dec 17, 2007 | 05:30 PM
HAPRECYCLING's Avatar
You need a special machine to bleed the modulator! I have heard a way of lifting all 4 wheels off the ground and let the car run. I have never seen it done? Just heard about it.
russianswty
Apr 5, 2007 06:44 AM
inline4me
Mar 19, 2007 07:15 AM
Ihatecars
Aug 28, 2006 10:05 AM
