How to acquire COP signal?
Old Oct 13, 2013 | 03:47 PM
FlewByU352's Avatar
Default How to acquire COP signal?
Since the Honda coils are individual you have the 3 wire design. A power, ground, and signal. When converting from a distributor setup, how do you send individual signals to let each coil know when to fire?
Old Oct 13, 2013 | 04:43 PM
EF9_TryMe's Avatar
Default Re: How to acquire COP signal?
Not 100% on how they work, but I'm assuming the signal wire is the input in which receives a command coming from the ecu, and then has a driver either inside the ecu or the coil itself that closes off a circuit and fires off the coil.
Go ahead, and correct me if I'm wrong.
PistonRings
Engine Management and Tuning
22
Apr 30, 2018 04:18 AM
jtracing919
Jan 11, 2005 06:45 AM
jtracing919
Jan 11, 2005 06:41 AM
CimorelliCRX
Sep 21, 2002 02:20 PM
