Hondata trouble please help
Old Sep 24, 2003 | 05:15 AM
quik1's Avatar
Default Hondata trouble please help
I have the s200 system in my car and everything was working good until yesterday when I put in some rc 310 injectors. The light on the box is flashing fast and there is nothing on that in the manual. Could the injectors have anything to do with it cause I swapped the other ones back and they are running like crap now too and the light is still flashinf fast. I have tried resting the ecu.
Old Sep 24, 2003 | 10:51 AM
Spunkster's Avatar
Default Re: Hondata trouble please help (quik1)
sounds like a wiring issue. Just changing injecotors themselves will not have any effect on the chip in the ecu...it may not run the same since these are larger or smaller injectors though.
Old Sep 24, 2003 | 03:29 PM
quik1's Avatar
Default Re: Hondata trouble please help (Spunkster)
Bump
Old Sep 24, 2003 | 03:54 PM
spaceman's Avatar
did you get the correct kind of injectors?peak/hold or saturated i think those are the two kinds
Old Sep 24, 2003 | 06:17 PM
quik1's Avatar
Default Re: Hondata trouble please help (spaceman)
Ya they are the right kind (saturated). I called Hondata today and they said that there could be something wrong with the wiring but it was working fine before. It just seems weird that I put the injectors in and then the light starts flashing. I wonder if the ecu or the hondata box got screw up some how because even when I just turn the key to the on position it flashes fast.
Old Sep 25, 2003 | 07:24 PM
quik1's Avatar
bump
b18psi
Jul 2, 2004 02:24 PM
95ONE
Mar 3, 2004 07:41 PM
madman604
Feb 11, 2003 09:45 AM
ALLMOTOR18
Jan 30, 2003 04:25 PM
boomslang
Aug 29, 2001 06:50 PM
