Hondata stage1 vs. V-AFC2
Old Oct 9, 2003 | 10:09 PM
Wilky's Avatar
Default Hondata stage1 vs. V-AFC2
I have a 99 Civic Si, with I/H/E. My question is whether I should go for an Apexi V-AFC 2, or purchase a Hondata stage1. My intentions, long term, are to stay all motor, with a possible full build somewhere down the road -- CTR cams & gears in near future. I remember reading that you can adjust VTEC engagement with the Hondata, but how compicated is that? How much real control will I have over my fuel map with the AFC? Oh, and here is one that everyone will love, I live nowhere near a shop with a dyno, so Hondata will be run on a basemap for a while. Will I see gains?
Old Oct 9, 2003 | 10:13 PM
Mochanic's Avatar
Default Re: Hondata stage1 vs. V-AFC2 (Wilky)
Hondata!!!
way better, way more tuneable and reliable.
Old Oct 9, 2003 | 11:55 PM
Wilky's Avatar
Default Re: Hondata stage1 vs. V-AFC2 (Mochanic)
How tunable will it be without access to a dyno. What kind of wiring differences are there between the two? Are there any "on-the-fly" adjustments I would want to be able to make that I cannot with the Hondata?
Old Oct 10, 2003 | 12:17 AM
Mochanic's Avatar
once your car is tuned, you should not have to mess with it...
The Hondata simply goes in your OBD1 ECU, no wiring! The VAFC, must be wired into your ecu harness, which means cutting and splicing your harness
You can street tune it to within less than 5% of a dyno if you get a tuner that knows what he's doing!
Old Oct 10, 2003 | 12:34 AM
Kirei's Avatar
VAFC-2 can work with regular v-tec?
Old Oct 10, 2003 | 01:59 AM
Wilky's Avatar
So tuning it myself means purchasing the ROM tuning software, right? It almost wouldn't be worth it considering I could get it professionally tuned for less $ plus the gas for the 4-hour drive to get to Atlanta (nearest tuner to my knowledge). Will I make more power simply by installing it with a basemap?
Old Oct 10, 2003 | 10:20 AM
Mochanic's Avatar
there are some tuners out there that can go by what you tell them your setup is, they will use a known good base map and just make the adjustments to fit your needs.
This will be closer than you will probably ever get with the VAFC if your tuner is any good.
Old Oct 10, 2003 | 10:35 AM
1_bad_EF's Avatar
hondata
I hate Vafc/Safc's I totally regret buying the safc(2yrs ago) i have now. I wish hondata was around back then like they are now.
Old Oct 10, 2003 | 12:45 PM
NCcwITR's Avatar
Default Re: Hondata stage1 vs. V-AFC2 (1_bad_EF)
I have a Apex'i VAFC... Im going to get Hondata. hope thats simple enough for you.
Old Oct 10, 2003 | 04:21 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
Default Re: Hondata stage1 vs. V-AFC2 (NCcwITR)
first and formost hondata is way more tunable than a vafc will ever bee. but i have a vafc in my car and i like it. second the vafc2 was design for the new si and rsx so save your money and just buy a used one unless u just have to have that new gray case
rustydusty1717
Engine Management and Tuning
59
Dec 15, 2008 05:00 PM
harwood39
16
Sep 15, 2004 06:38 PM
