Hondata S200
when u purshase the S200 by Hondata....what exactly do u get with it???because i have the blue box thing pictured below but i was wondering if there was anything else to it...like a chip or anything...if there is, is there a way i can get the missing stuff??thanks in advace..
u get the serial wire, the one connector wire to ur ecu, the button for the setttings and the wire to the clutch switch (which is sold separately). you should also get the nessisary stuff to install onto ur ecu.
ok...so that means i need stuff to it...the only wire i have is the 4 wire plug that plugs to the very right plug in the picture...it has a black, brown, red, and orange wire...that would be which one????
pretty much all i have is this
edit*
just searched ebay and found this....so that means im missing all of this except the blue box and wire listed above...how can i get the rest of the stuff??
http://cgi.ebay.com/ebaymotors...QrdZ1
Modified by B18CivicEH2 at 9:43 PM 3/16/2007
edit*
that is the one that goes into the ecu, u still need the two other black ones and the serial cable for data logging, but thats not really needed unless ur going to use datalogging. one of the wires goes to the red button that allows u to adjust the settings like rev limiter and launch control, it should come with a button also. thats really the main things thats supposed to come with it
stocker2shocker91
May 22, 2011 06:25 PM
A.E Motoring
May 30, 2006 11:33 PM
