high speed shaking
Old Nov 11, 2003 | 05:24 AM
iwhichisme's Avatar
Default high speed shaking
I know this is a pretty common problem among older cars. My car is a 93 hatch, and when ever im cruising at around 80mph steering wheels shakes. Some times it bothers me and sometimes it doesnt, but im just wandering what needs to be replaced to fix this problem?
Old Nov 11, 2003 | 05:29 AM
doublejz's Avatar
Default Re: high speed shaking (iwhichisme)
your tires probably need spin balanced
Old Nov 11, 2003 | 05:35 AM
iwhichisme's Avatar
Default Re: high speed shaking (doublejz)
well ive just purchased brand new rims and tires about a week ago, so i doubt it could be them. Ive heard that it may be the tie-rod ends, but im not 100% sure thats the problem.
Old Nov 11, 2003 | 05:52 AM
wickedEFguy's Avatar
if your still shaking then your tires are not balanced properly. Also if your braking and your shaking after the wheels have been balanced properly then your rotors are probably warped
Old Nov 11, 2003 | 07:07 AM
JimBlake's Avatar
Default Re: high speed shaking (wicked B16)
It could be a loose ball joint somewhere. Lift the car, grab a wheel, & try to move it. If there's any looseness you've gotta find WHERE it's loose.
Try moving the wheel like you're 'steering' it. If it moves this way it might be the ball joint at the end of the steering rack. If it's loose up&down then maybe upper or lower ball joints. Either way it could also be a loose wheel bearing.
Old Nov 11, 2003 | 07:09 AM
iwhichisme's Avatar
Default Re: high speed shaking (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">It could be a loose ball joint somewhere. Lift the car, grab a wheel, & try to move it. If there's any looseness you've gotta find WHERE it's loose.
ill give that a try when i get off. I was thinking it had to be something like that.
Old Nov 11, 2003 | 03:06 PM
vtekstorm's Avatar
if it is a ball joint get that taken care of asap. my friend hada bad ball joint and everntually the the whole sterring knuckle fell of and the wheel fell outward. you know what it might be also the tires might be on going in the wrong direction if you have direction tires. theres an arrow on the sidewall that pints in the direction the wheel is supposed to spin. maybe that might help
prelude_93vtec
Sep 19, 2009 10:50 AM
fbankins
Suspension & Brakes
Aug 8, 2006 07:03 PM
mugenpwr17
May 15, 2006 05:11 PM
lowRIDAH
Suspension & Brakes
Sep 29, 2005 03:05 PM
Nizzy
Aug 21, 2003 07:31 AM
