High Idle is driving me crazy
Old Oct 8, 2010 | 12:10 PM
teknicalissue's Avatar
Default High Idle is driving me crazy
Yes my JDM b16 SiR2 is idle'ing at 1,500 RPM. its annoying...
Yes i cleaned out the IACV
Yes i checked the screw in the FITV + cleaned it
Yes i checked the screw in the Throttle Body
Yes i bought a new MAP
Yes i replaced ALLLLLL of my gaskets
No... i don't know what to do
EDIT: I have new ngk wires new plugs and new cap+rotor..
The idle'ing is consistant, it stays at 1,500 when its both Hot and Cold
Old Oct 8, 2010 | 12:27 PM
ruffrhyder's Avatar
Default Re: High Idle is driving me crazy
Check for kinked throttle cable, or stuck open throttle body butterfly. Might need to adjust the throttle body butterfly set screw. Also, check for a vacuum leak.
P.S. this doesn't belong in the "all motor" forum. threads like this should be in "tech/misc" forum
Old Oct 8, 2010 | 12:32 PM
Checked, all is fine (also its not too tight and not too loose
checked out the butterfly and it visually looks good.. but im not sure how to test this
that is what i first thought, but there is no leak.
p.s sent a message to the admin so he can move the thread
Old Oct 8, 2010 | 12:42 PM
ri_rv's Avatar
take off your intake and plug up the FITV hole inside your throttlebody with your finger, if the car still idles high then you definately have a leak through your FITV. I changed the gasket and cleaned it and it was still my FITV. have you tried spraying carb cleaner around suspected areas of the manifold?
Old Oct 8, 2010 | 01:01 PM
there's two holes. the one on the bottom (which i assume goes to the FITV) if plugged, nothing happens (still idles high)
but if you plug the one on the top, idle goes perfectly to 1k.
Old Oct 9, 2010 | 07:23 AM
RHD_BB4T's Avatar
Unplug the iacv and see it if changes. or tap on it with a hammer.. I said tap not tim taylor that thing.
Old Nov 2, 2010 | 04:26 PM
Rigginit's Avatar
ECT can be bad and not throw the code. Try that maybe if the rest doesn't solve it
Old Nov 3, 2010 | 01:25 AM
eg6nike's Avatar
i would follow this lead quite closely. from my little experience i feel like either valves being bad would cause an erratic idle and not the constant 1500 rpm idle (hot or cold) but if the ect sensor was messed up the ecu wud think the coolant was always cool and the fitv would never turn off. just my take good luck with the fix.
raverx3m
Apr 21, 2013 05:07 PM
95_red_dc
Sep 11, 2006 09:47 PM
LilManSi
Jan 26, 2004 04:12 PM
Initial DA6
Aug 29, 2002 03:24 PM
