high idle 99 gsr
Old Feb 14, 2006 | 02:00 PM
CivicBwoy's Avatar
Default high idle 99 gsr
yes i have searched
i have a 1999 gsr that was idleing up and down ever since its been tuned on crome pro.. with 525cc
i changed tha iac valve, and after changing it the idle now stays at 2000 rpm,... i cant find a vacuum leak anywhere, i took off and cleaned the t/b and even replaced it with a different 99 gsr tb,..and it still idles high
this is a obd2 so the tb doesnt have the ficv that i have read about in other post
also whenever i cover the top hole inside the tb( i think it goes to the idle screw) the idle goes down,..if i cover it fully the engine shuts off....
i am now thinking about replacing the tb gasket
also my boost gauge stays at 21" of vacuum
Old Feb 15, 2006 | 06:30 AM
CivicBwoy's Avatar
will be changing tb gasket today,...
will keep updated
Old Apr 17, 2006 | 05:59 PM
9WON4's Avatar
Default Re: (CivicBwoy)
GOOD LUCK , MAN!
Old Apr 17, 2006 | 08:17 PM
so lazy's Avatar
Default Re: high idle 99 gsr (CivicBwoy)
do this... take your TB out theres a little plate thats at the bottom behide the TB that has 2 phillips head screws holding it on... open that and check to see if the spring is all the way out... if it is SCREW it back in a bit and put everything back together then start your car and let it warm up... GOOD LUCK
dtarvin
Nov 19, 2008 01:45 PM
StreetRacinThug
19
Mar 24, 2006 12:59 PM
socki18
Apr 7, 2005 05:43 AM
ITRacer121
11
Mar 25, 2005 01:49 PM
