hf manifold on zc??
Old Dec 7, 2003 | 11:13 AM
dan89crxsi's Avatar
Default hf manifold on zc??
Willl the CRX HF manifold fit on a JDM DOHC ZC motor???
Old Dec 7, 2003 | 11:16 AM
Jim Truett's Avatar
Default Re: hf manifold on zc?? (dan89crxsi)
Can you survive breathing through a straw?
Old Dec 7, 2003 | 11:46 AM
dan89crxsi's Avatar
Default Re: hf manifold on zc?? (Jim Truett)
so is that a yes but restricted airflow.....then what about the std mani bigger runners right???
Old Dec 7, 2003 | 12:27 PM
Jim Truett's Avatar
First, are you referring to the intake or exhaust?
Old Dec 7, 2003 | 03:33 PM
Kendall's Avatar
If you are referencing the exhaust manifold, then yes it will fit but I wouldn't use it for anything except a turbo manifold. And even so, it would be in your best interest to go ahead and get a good turbo manifold with the proper flange to fit a turbo.
Old Dec 8, 2003 | 09:33 AM
dan89crxsi's Avatar
Default Re: (dc231)
yes I am referring to the exhaust manifold and it is for a turbo setup I am planning on using the std mani and port matching it to the zc sound good or bad idea?
Old Dec 8, 2003 | 04:36 PM
virginia_dude's Avatar
Default Re: (dan89crxsi)
I thought the Newer CX manifod had bigger runners and ports, followed by the STD and then the HF, or am I wrong. All of which could be used as a turbo manifold.
Old Dec 8, 2003 | 04:48 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dan89crxsi &raquo;</TD></TR><TR><TD CLASS="quote">yes I am referring to the exhaust manifold and it is for a turbo setup I am planning on using the std mani and port matching it to the zc sound good or bad idea?</TD></TR></TABLE>
It depends on how much money you want to spend. I'd go ahead with the extra $200 or so and get a good manifold. It will flow better and you won't have to make a flange adapter.
ludesrv
Feb 21, 2006 08:51 AM
deerek101
Jan 16, 2006 10:30 PM
dank9513
Jun 13, 2003 06:04 PM
kshymkiw
10
Oct 31, 2002 04:41 PM
fkncivic
Oct 1, 2002 12:54 PM
