Hey guys! newbie here... fuel riser failure? is it likely?
Hello everyone, my names Dustin and I'm a race-aholic...
I have a newly built setup that hasn't been tuned yet, which I ran on a dyno today to check things out. the boost is set around 6psi during this run, and the A/F went off the chart lean. The test was stopped at 3.5k rpm so I don't have to buy another motor (yet).
I'm just wondering if anyone can look at my setup and check out this A/F curve and let me know what they think could be the problem (bad fuel riser, injectors saturated, etc..)
here's a link to my setup (mod list at bottom of first page):
http://www.cardomain.com/id/turbosi
Hopefully the Hondata will fix this
Thanks in advance for any help!
ive got a couple questions
what is your fuel setup? (exact setup, everything from pump to pressure regulator)
and are you using anything like a SAFC or VAFC for mixture control?
here's all I have right now:
- STR fuel rail
- Holley 255lph fuel pump
- B&M fuel regulator
- Vortech fuel riser
no vafc
I don't know the fuel raise ratio, and this is with stock injectors (B16A2 motor).
the thing is, I had this setup running before I had the motor rebuilt (second time) and I didn't run out of fuel like this. It seems like the fuel raiser is not doing its job all of a sudden. something must have changed with the fuel setup when the motor was rebuilt? Only thing I knew of is one injector was replaced because they said it went bad, and they replaced it with Botch. did I miss any info?
- STR fuel rail
no vafc
well here is what i was always taught for hondas that are boosted
If you use:
intank pump, get injectors
inline pump, get a FMU
now is the pump inline or intank?
If you use:
You already have all that money into the motor, when not spend a little more and get yourself a standalone like Hondata. That would solve all your problems and make your car run extremely well.
hmm, I don't know if its inline or intank. I bought this car with the turbo setup already on it, I'm still learning about the stuff I have. I thought the fuel pump was mounted on my firewall with the fuel gauge on it??
If thats not it then I guess it's intank...
I have the Hondata (S100 w/ boost) on order along with 780cc injectors. hopefully when I install those and take out the fuel riser, my problems will go away.
I would like to find out root cause before I start changing parts though.
ok, I'm pretty sure that what I circled abuve was the fuel filter, and my fuel pump is intank (I figured that out on my own). so now you know what kind of beginner your dealing with
