HESITATION
Old Jul 17, 2001 | 05:25 PM
95PRELUDEVTEC's Avatar
New User
Default HESITATION
i have a 95 prelude vtec. i recently did a tune up (oil, fuel filter, spark plugs, spark plug wire, valve adjustments, and a new catalytic converter because it was clogged).
my problem is it keeps on hesitating at 2700rpm to 3700rpm. whenever i floor it or switch gears it hesitates.
can anyone help me??? my baby isn't running the same anymore.
Old Jul 17, 2001 | 06:43 PM
GruvyTune's Avatar
New User
Default Re: HESITATION (95PRELUDEVTEC)
Dude,
I have a 95 GSR and it does that to me too. I just finished putting in a Skunk2 manifold, new fuel rail and new Type R injectors, B&M fuel regulator and gauge, new plugs, changed my timing belt and water pump, put in an undersize crank pulley and adjusted my valves. I have my timing gears at stock settings till I can Dyno tune.
I get the same kind of hesitation as I accelerate and get close to 3000 rpm. After that I get pretty smooth acceleration--even better than before.
Why the hesitation?? I have no clue. I don't find any vacuum leaks or anything. Don't burn a drop of oil and have never suspected a compression problem.
Any help in what to look for would be appreciated.
thanks
tf
fixinit
May 4, 2004 10:21 PM
GruvyTune
Jul 25, 2001 10:42 AM
GruvyTune
Jul 20, 2001 01:52 PM
95PRELUDEVTEC
Jul 19, 2001 03:17 PM
