help! taking off hub for lug conversion
Old Jan 31, 2003 | 04:55 PM
htownteg's Avatar
Default help! taking off hub for lug conversion
i have a puller that pulls off the hub...but all the puller does is push the axel inward, jamming into the tranny...how do i get the hub off
Old Jan 31, 2003 | 06:01 PM
ChiBoy's Avatar
Default Re: help! taking off hub for lug conversion (htownteg)
When I took my hubs out to put in new bearings, I used a press. The knuckles had to come off of the car to get them in/out. I've never heard of anyone taking them out while still on the car. I would recommend borrowing a Helms.
Why are you taking out the hubs anyway? What kind of conversion are you doing?
Old Jan 31, 2003 | 06:17 PM
htownteg's Avatar
Default Re: help! taking off hub for lug conversion (ChiBoy)
my lugs are messed up so i have to replace the lugs which are in the hub....wats the easiest way to take off the knuckles...by disconnecting the control arms maybe?
Old Jan 31, 2003 | 06:27 PM
ChiBoy's Avatar
You would need to break loose the upper and lower ball joints and the tie rod.
If you're only trying to replace studs, there's a way to do it without taking off the hubs. Somehow you grind part of the stud so it will slip in behind the hub.
Try a search, or repost about replacing wheel studs.
Old Jan 31, 2003 | 07:26 PM
htownteg's Avatar
oh yea i forgot to mention its an integra...theres no clearance to remove the studs from behind the hub...
Old Jan 31, 2003 | 08:09 PM
1SlowB16EF's Avatar
take the entire spindle assy off and use a hydrolic press
Old Feb 1, 2003 | 06:47 PM
htownteg's Avatar
Old Feb 1, 2003 | 06:48 PM
htownteg's Avatar
im just going to get a used knuckle and hub/bearing assembly from a salvage yard
S2Integra
Mar 16, 2010 10:37 AM
radicaled434
Aug 25, 2009 11:18 AM
BlueLude 94
Jan 24, 2006 10:55 PM
DC4KiD
Mar 7, 2005 09:32 AM
CRX_GUY_123
May 8, 2004 07:00 PM
