Help, smoking LSvtec
Old Mar 26, 2004 | 01:11 PM
thad
Guest
Posts: n/a
Default Help, smoking LSvtec
i just got done helping my friend build and install his LsVtec and once we started it we got massive amounts of white smoke from the exhaust, and a pretty big head gasket leak. we did a compression test and all cylinders came up between 170 an 180 psi except #4 which had no compression at all. when we pulled the spark plugs they were each wet (oil). right now i'm thinking it's a bent valve or valves in number 4 sticking open, and maybe across all the cylinders. we checked the head before we got it to make sure there were no bent valves by shooting carb cleaner into the intake and exhaust ports and there were no leaks too indicate bent valves.
any ideas are welcomed.
here the setup: all stock B16 head and pistons
golden eagle dowel pins, oem headgasket with exhaust side rivets removed.
Old Mar 26, 2004 | 06:55 PM
notstock93's Avatar
Default Re: Help, smoking LSvtec (thad)
bent valves would be very obvious at idle.
Sounds like he needs a new HG, is all. There is a chance that the head and/or block is warped, which wont allow the HG to seal properly. How many miles on the LS block?
Old Mar 26, 2004 | 07:47 PM
thad
Guest
Posts: n/a
Default Re: Help, smoking LSvtec (notstock93)
not sure how many miles, but the valves do tick really loud at idle, we just checked the clearances and only two intake valves were to spec. one intake valve had a clearance of .020", and a bunch of the exhaust valves were at .0035". could it be that the exhaust valves are stretched, or maybe just poorly adjusted.
black teg
Dec 4, 2013 10:29 AM
mediajunkie420
Oct 7, 2013 12:34 PM
PphamEK
11
Apr 17, 2009 09:13 AM
blackeg
Jul 9, 2006 09:13 PM
91-lsvtecsi
Apr 29, 2006 08:31 AM
