HELP with shift forks/linkage!!
Old Mar 24, 2007 | 08:26 PM
203_DC5's Avatar
Default HELP with shift forks/linkage!!
I have a 89' crx si with a D16A8 swap but the tranny is the original L3 tranny. I need some help because its really hard to get it into gear and just today it got stuck in 1st even though the shifter was in neutral. My brother has a DSM and he says that it happened to him and all he did was adjust the shift linkage and fixed the fork and it worked. My qusetion is, is it possible to adjust the linkage and fork or what would i have to do?
Old Mar 25, 2007 | 10:03 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: HELP with shift forks/linkage!! (LFMotorsportsowner)
Has the shifter bushings been replaced???
The car is almost 20 years old, and they are known to be a problem. Usually a sloppy shift lever when in gear.
As far as getting stick in first, THAT is bad news, but you need to describe the scenario better.
Old Mar 27, 2007 | 05:34 PM
203_DC5's Avatar
Default Re: HELP with shift forks/linkage!! (Mista Bone)
alright...this is what happened. the car ran fine for months then last week while just sitting there at idle the tranny made a kinda bad noise and then made a continues grinding noise, then it all of a sudden turned off on its own. then i started it up again but when i lifted my foot off the clutch it stalled out on its own even though it was in neutral. i tried messing with it and tried to see if it would go into reverse but nothing worked and it still would stall out if i lifted the clutch.
Old Mar 27, 2007 | 08:05 PM
Mista Bone's Avatar
D Tranny Guru
I'll go with exploded diff or spider gear, or shifter fork piece broke off.
Old Mar 28, 2007 | 06:23 AM
203_DC5's Avatar
Yea my brother said maybe shifter fork is broken but i went under the car yesterday and its still intact so i think im gonna go with blown gear so i figure im just gonna swap trannys. probably the best solution. thanks dude.
Old Mar 28, 2007 | 10:20 AM
Mista Bone's Avatar
D Tranny Guru
Shifter forks are INSIDE the tranny, you can't just get under the car and look at them.
Old Mar 29, 2007 | 08:30 AM
203_DC5's Avatar
Default Re: (Mista Bone)
well the linkage is fine...but either way if the fork is broken then the tranny still needs to be replaced, right?
Old Apr 1, 2007 | 11:10 PM
Mista Bone's Avatar
D Tranny Guru
removed and repaired, yes.
replaced, no.
Hatchbacksonly
Dec 2, 2012 04:20 PM
honcrx91si
Aug 25, 2006 08:24 PM
loclowd
Oct 10, 2005 11:40 AM
wu tang
Jun 25, 2003 11:47 PM
