HELP Screeching after installing new Starter???
Old Jan 3, 2005 | 10:59 AM
LOWLIFEHATCH's Avatar
Default HELP Screeching after installing new Starter???
I just installed a new starter on my 96 accord and now when I turn the car over there is a screeching noise just as it turns on? Is there something i did wrong? I just took the old one off and installed the new one with the reverse steps as taking it off? Thanks for any help
Old Jan 3, 2005 | 12:33 PM
Default Re: HELP Screeching after installing new Starter??? (LOWLIFEHATCH)
Is it maybe cause its new I am just turning the key to hard? Its almost sounds like what happens when your car is running and you turn the ignition. It doesnt seem to do it if im gentle turning the ignition. IDK???
Old Jan 3, 2005 | 12:54 PM
SuperTeg95's Avatar
could be shimmed wrong. Did it come with shims or did the old one have shims? Sounds like the started isn't perfectly seated against the tranny correctly.
Old Jan 3, 2005 | 01:55 PM
Default Re: HELP Screeching after installing new Starter??? (SuperTeg95)
It didnt come with any shims and I double checked things to make sure it seated right and then took it off again to triple check and it was seated fine. Idk it doesnt make the noise all the time now just some times maybe cause its new?
Old Jan 3, 2005 | 02:50 PM
cletus's Avatar
is it an oem starter or a autozone/pep boys unit?
Old Jan 3, 2005 | 06:37 PM
Default Re: HELP Screeching after installing new Starter??? (cletus)
Napa
Old Jan 3, 2005 | 07:22 PM
cletus's Avatar
i see.....i would use an oem unit, but i understand sometimes that cant be done. if you can afford it try an oem starter.
Old Jan 4, 2005 | 08:52 AM
SuperTeg95's Avatar
just return it and get another. NO big deal. Their starters are usually lifetime warrantied anyway. I got advance on mine and its went out on me once but I just took it back and got another without any questions. It only take a second to replace a starter on a honda any way.
Old Jan 4, 2005 | 03:02 PM
cletus's Avatar
there's a reason its got a lifetime warranty........
i know its not hard to change, but i would get oem and not worry about it again.
do it right the first time instead of next year and a month later and a year later and two days later etc.......
mikeyleed
Aug 3, 2010 12:00 PM
civica
Oct 3, 2008 07:21 AM
JLefevers
Apr 19, 2006 06:55 PM
CiViC I2aCeI2
Aug 5, 2005 11:51 PM
B18Cej1
Aug 4, 2004 07:03 AM
