obd2-harness rewired to obd1?
my buddy bought a 98 gsr motor and we just found out that the wire harness plugs into a obd1 car, yet still works on the obd2 motor.
i thought this was wierd
anyone have this done? i thought in order to run an obd2 motor in an obd1 car, you either have to change the distributor, injectors and harness or swap the harness to obd2 and run a jumper harness.
THANKS
THANKS
Re: obd2-harness rewired to obd1? (253EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 253EK »</TD></TR><TR><TD CLASS="quote">
THANKS</TD></TR></TABLE>
Actually you can use an obd2 injectors distributor on a obd1 car, you can use the engine harness from an obd2 integra on an obd1 car (ex: 92-95 civic) because the plugs are the same from the engine harness to the chasis harness, the only diff I think is the extra o2 sensor plug on the obd2 harness, other than that it can work if I'm not mistaken.
-l8r
-l8r
Re: obd2-harness rewired to obd1? (civicdx860)
thanks for the reply. i just thought that the obd2 harness wouldnt plug into the chassis harness.
TTT
TTT
ExtraBlackRex
07-07-2011 03:10 PM
