HELP WITH OVERFLOW PROBLEMS WITH CATCHER CAN SETUP!!!!!!!!!
could someone please help and give me some sort of simple answer?
ok i have been running in my boosted b16 and the more i have been putting the gas down the catcher can has been overflowing!
i have
vented catch can
b r fittings block plug and block port fitting
i have one line coming from the valve cover
and one from the block port in the back of the block!
so i have removed all the pcv valve and box
could some one please give me some help on my the issue as iam stumped
thanks very much in advanced
i have
vented catch can
how would i do a check valve?
when iam driving slow it only fills up slowly but when iam hitting 10psi it fills up really quick and i mean quick!
motor has just been rebuilt fully
150 psi on the compression tester
also iam thinking could i run a catch can for the front of the valve cover and keep the one i have in the back?
have i got to much blow by when on boost?
ive not got any pics at the moment
but iam just running the vc from the stock valve breather
when you run a oil catcher can setup do you need to get rid of all the pcv valve stuff?
hope someone can help me out
thanks
thanks
HandMadeEgRHd
May 8, 2010 06:29 PM
