help with OBD2 LS swap in EG
Old Sep 24, 2003 | 06:04 PM
CivicSiLS's Avatar
Default help with OBD2 LS swap in EG
ok i am putting in a B18b1 from an auto..i am having some problems of where to put some of the vacuum lines and 1 plug....
OK on the TB of the D16 it has this little nipple that protrudes from the TB
now the LS one doesn't
Where do i plug the vaccum line from the cannister on the firewall to the TB on the LS?? DO i need a OBD1 TB??
and also i have this on my D16
where do i plug the 1 plug and the vacuum line to on the LS manifold??
Are OBD1 and OBD2 ls maniolds and TB's different?? is there a difference from ato to maual?
thanks
Old Sep 24, 2003 | 06:32 PM
poison's Avatar
Default Re: help with OBD2 LS swap in EG (CivicSiLS)
Ok for the evap canistor hose, there should be one on the LS TB. Can you take another picture of the LS TB more "out" to see the whle TB?
As for the rear part of the Intake manifold. That nipple goes to the brake booster, and that solenoid would be the Purge Control solenoid which is also on the D16Z6.
Old Sep 24, 2003 | 07:19 PM
CivicSiLS's Avatar
Default Re: help with OBD2 LS swap in EG (poison)
that picture of that Purge solenoid is the d16 manifold...in this pic it shows the plug..and no purge on teh 18 motor?
str8drift
Oct 31, 2007 03:34 PM
6doorsentra
Jul 10, 2007 02:47 PM
92civichatch1
Oct 21, 2005 05:34 PM
go2sleep
Aug 2, 2005 08:24 AM
1990hondaHF
Jun 8, 2003 07:04 AM
