brakes with drag slicks
Old Nov 20, 2002 | 09:48 AM
autoEXturbo's Avatar
Default brakes with drag slicks
I'm just curious as to what if at all i can change to that will still clear 13in lensos or bogarts up front. Right now i'm running power stop rotors, but i didn't know if there is something better that will work. I was told that i have to use stock calipers and rotors to fit. Any help will be appreciated.
Kellen
Old Nov 20, 2002 | 09:55 AM
Kataku2K3's Avatar
Default Re: brakes with drag slicks (autoEXturbo)
Are they just stock Civic brakes, as in you power slots are the same size as the original rotors?? If so your Lenso's or Bogart's will work fine...
Old Nov 20, 2002 | 09:57 AM
Default Re: brakes with drag slicks (JDMspecEG6)
yea, the power slots worked just fine underneath the bogarts. But on the street the brakes aren't the best. I'm just curious if i upgraded the rotors and caliper if the slicks will still work. I don't need to step up to a bigger rotor, but something that has more stopping power.
Old Nov 20, 2002 | 11:48 AM
SlowTeg's Avatar
You can't really upgrade the brakes w/o upgrading the rotors.. They're too small and can't withstand much heat..
Well.. unfortunately the only upgrades that are really worth doing for the 10.3" brakes include stepping up to a larger diameter rotor, and anything larger than your stock brakes (such as type-r front brakes 11" rotor), will require you to ditch the 13" slicks. Yeah, it definetly sucks, but there's really nothing you can do...
The other option that alot of people do is swap spindles and install the smaller brakes for the track, then swap them back out after the race. Yeah, it's a little bit of work, but nothing's easy..
-Mike
Old Nov 20, 2002 | 11:52 AM
Default Re: brakes with drag slicks (SlowTeg)
yea, oh well, looks like i'll just upgrade to better pads and hope that helps. It's not like can do much racing in the corners anyway, strictly a straight line car.
shwepes
Suspension & Brakes
Jan 23, 2016 06:17 PM
SurferX
Mar 10, 2003 12:32 AM
Veil_Side_
Jun 29, 2002 11:07 AM
Conechaser
Feb 6, 2002 10:42 AM
