HELP! not getting power at the radiator fan plug
Old Nov 29, 2006 | 07:47 PM
timisyourfriend's Avatar
Default HELP! not getting power at the radiator fan plug
1994 Honda Civic EX Coupe
changed temp switch, getting power to switch, big fuse replaced, its not the fan because its just not getting power to the plug. y no power to the plug??? headache!
Modified by JZPerformance at 5:34 AM 11/30/2006
Old Nov 29, 2006 | 08:00 PM
JimBlake's Avatar
Default Re: HELP! not getting power at the radiator fan plug (JZPerformance)
If you don't tell us what year or model, you'll just have to get circuit drawings on your own. Honda used maybe 3 or 4 different control schemes over the years, not to mention maybe if you're talking about a '72 pinto or whatever...
Old Nov 29, 2006 | 08:33 PM
Default Re: HELP! not getting power at the radiator fan plug (JimBlake)
lol. oops? 94 Civic Ex Coupe
I have the circuit diagram, but still can't figure out what's wrong. I checked pretty much everything that i know of.
Old Nov 30, 2006 | 05:04 AM
JimBlake's Avatar
Does the '94 Civic have a fan-timer module like the Accord? If so, that's a good possibility. It has the switching logic that goes from one fan switch with engine running, to a different fan switch when the car is off. It's capable of interrupting the circuit for either one of these fan switches.
Did you check the fan relays? (Separate from the timer module.)
Old Nov 30, 2006 | 09:15 AM
Does not have the module. At least not in my manual. I did check the relay like 10 times. I used a new one, I tested one and then used it, still the same.
Relay should be the one closest to the firewall in the under the hood fuse box. Is there another?
Old Nov 30, 2006 | 12:29 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JZPerformance &raquo;</TD></TR><TR><TD CLASS="quote">Relay should be the one closest to the firewall in the under the hood fuse box. Is there another?</TD></TR></TABLE>I don't own a Civic so I'll have to go along with your wiring drawing on that...
Are you getting power to the relay socket?
Are any of the actual connectors pulled back from the socket so they don't make contact when you plug in the relay?
Did you check the relay off the car or did you listen for it clicking when you jumpered the fan switch?
Old Nov 30, 2006 | 12:38 PM
The fan relay socket is getting 1 volt. haha the one next to it gets 15-16, then the last one gets like 0. so.. weird.
I'm sure they make contact, plus like I said, I tried several relays.
I checked off the car. But I just assume if I tried so many relays, I'm sure one was good, especially when it worked on the other socket.
Old Nov 30, 2006 | 03:12 PM
anyone?
Old Nov 30, 2006 | 04:29 PM
exownzu's Avatar
dude id say screw the relays and all tht **** just rewire into the black/yellow wire of your distiributor the fan stays on all the time but it dont hurt nothin just keeps it a lil coller thts how mine is
Old Nov 30, 2006 | 05:15 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: (exownzu)
i had a problem like this with a civic tryed everything replaced the ecu for ****'s and it worked...if you have a spare try it
Old Nov 30, 2006 | 08:08 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JZPerformance &raquo;</TD></TR><TR><TD CLASS="quote">The fan relay socket is getting 1 volt. haha the one next to it gets 15-16, then the last one gets like 0. so.. weird.</TD></TR></TABLE>That IS weird. I'd be suspicios of the meter accuracy.
Does your wiring drawing show which terminal of the relay socket is power supply? The ones that aren't power supply, they probably are OK reading like that.
Old Nov 30, 2006 | 09:02 PM
Yea, of course I checked the 2 that are suppose to be power at all times. I'm sure the meter is accurate, I use it for everything.
Old Dec 1, 2006 | 06:43 AM
JimBlake's Avatar
Well, the 15-16v seemed strange to me. That's high even for a running alternator. Is your alternator output voltage that high?
Using the circuit drawing, where does the fan relay socket get its power from? Go 'upstream' looking for where the power is good.
joelro28
Feb 22, 2014 12:43 PM
94civicex.
Honda Civic (2001 - 2005)
Sep 6, 2010 05:56 PM
xTomei
Jun 18, 2010 03:09 PM
gophat
Jul 18, 2008 08:40 AM
GSE980
May 15, 2007 09:00 PM
