Help Installing My Heater Control
Old Oct 7, 2003 | 08:59 PM
STHPERFORMANCE's Avatar
Default Help Installing My Heater Control
Ok, on the back on the heater control there are several cables....
Cold-Hot select has two cables
Inside-outside vent has one cable
Air position selection has one cable
What i need help with is to where exactly do these cables go? I was told one go to the heat valve on the firewall but the resource wasnt 100% sure.
Keep in mind...... i have no A/c ......
Old Oct 8, 2003 | 08:00 AM
Default Re: Help Installing My Heater Control (Outkast)
T T T
Old Oct 8, 2003 | 08:12 AM
1_bad_EF's Avatar
there is a valve in the eng compartment that the hot to cold selector controls. It is prolly a push-pull style hence two cables
then there is a valve inside the cat that goes to the heater box to select where you want the heat.
In-out is the one thats left.
navcc
Apr 28, 2013 01:33 PM
fallmartin
Dec 2, 2008 05:01 PM
jmar97
Dec 13, 2004 10:51 AM
type gsr
Oct 19, 2004 07:23 AM
STHPERFORMANCE
16
Oct 10, 2003 07:38 AM
