HELP with injectors IPT and KEI HIN
Old Feb 25, 2004 | 12:29 AM
gaydm.accord's Avatar
Default HELP with injectors IPT and KEI HIN
application 99 gsr head
first my problem is i had a fuel leak turns out to be my injectors, i took off the fuel rail and low and behold the o rings are torn. so i take my injectors out and inspect them one of the injectors are cracked at the tip down toward the spray nossle. now i remembered that when i bought the car there were two injectors in the glove so i pull them out. problem its blue tip and instead of KEI HIN imprinted it says IPT.
ok i did some searching on google and found out that IPT is apart of KEI HIN so the injectors i have are stock. so the difference is the ones i have on now are some what clear tip but from use it turned brown. now the ones in the glove have an aqua blue tip.
so my question is what injectors do i have in the glove. and is it safe to use?
most honda and acura injectors are the same sohc or dohc with the exception of preludes. correct me if i am wrong.
will have pics up tomorrow.
RACEPAK
Apr 29, 2010 01:41 AM
hoskos
Aug 27, 2007 11:22 AM
BoostedsiR
Jan 28, 2004 06:48 AM
