B16A Problems
Old Feb 24, 2004 | 01:31 AM
crxkane's Avatar
Default B16A Problems
Back groung 90 Crx Si w/B16A. car was runnig fine when swap first went in. then started to have slight hesatation, kinda missing. then got even wors, here is the problem, when driving the other day, car was missing then just had no power like if it jumped timeing( this happend while driveing 60 on the highway.) bogged realy bad, would back fire while giving it gas, after limping it home, check code and had a code 4, replaced the dizzy with another obd 0 B16A one. reset ecu and restarted car, cel is now gone, code for is now gone but once the car gets to warm/operating temp it feels like if there is no power, like if there is build up of back pressure. when you take off it feels ok, but once you go to shift and get back on the gas is when you feel that you are not going to move, sluggesh????please help any advice woudl be greatly app.....
thanks
Old Feb 24, 2004 | 07:11 AM
mmuller's Avatar
Mad Scientist
Default Re: B16A Problems (kanecrx)
did you set the timing back to stock after replacing the dizzy?
Old Feb 24, 2004 | 09:32 AM
92b16aTurbo's Avatar
Default Re: B16A Problems (mmuller)
Try replacing the fuel filter too....
Old Feb 24, 2004 | 07:26 PM
chameleon's Avatar
Default Re: B16A Problems (92b16aTurbo)
both are good suggestions to try out. what computer are you using and what is your timing at ? also on an older engine check that your injectors arent clogged. also is your head ground in the right spot ?
Old Feb 25, 2004 | 12:53 AM
crxkane's Avatar
Default Re: B16A Problems (chameleon)
I am running a PR3 man. ecu. I have not been able to check timing yet, need to get a timing light. replacing the fuel filter was the next thing to change. I will need to check that my injectors are not clogged, I know that some of the o-rings on them need to be relpaced. any other sug.???
illicit_kustomz
Sep 14, 2008 01:08 PM
jdm-lab
Feb 21, 2007 09:45 PM
Boosted Chemist
12
Aug 1, 2004 08:14 AM
