Help!!!! im mad right now.....:mad:
Old May 30, 2010 | 05:33 AM
ekplatano's Avatar
Icon2 Help!!!! im mad right now.....:mad:
i need help with my car is a 97 civic hatchback with a d16 n is not turning on i really dont know waz wrong with it well here we go .
it cranks but doesnt turn on i really dont know if its getting spark. when i turn the key in the ignition the check engine light is there and then it turns of like for about lees than a second and something does like a cleak on the dashboard on the passenger side.. i know its not the distrubutor cuz my stupid uncles friend told me that it was that n when when a bought one and put it on the same **** happen i really dont want to spend some hundreds of dollar taking it to a mechanic pleace help................ i will post a video tomorow to let u guys see better cuz im kind of a nubbie
Old May 30, 2010 | 05:34 AM
ekplatano's Avatar
Default Re: Help!!!! im mad right now.....:mad:
help me honda tech i have to take her out asap
Old May 30, 2010 | 06:26 AM
dc2luver's Avatar
plugs?
Old May 30, 2010 | 07:07 AM
Honda Bull's Avatar
You are providing ZERO info, so how can we help you at all?
Does the engine crank? Does the starter work at all? Is it getting the current from the battery? Is the spade terminal on the starter?
Does the ECU get power? Does the fuel pump prime?
If the engine cranks, does it have spark? Is the firing order on the plug wires correct?
Simple things, man. Go over it all.
Old May 30, 2010 | 07:28 AM
siblues's Avatar
Did it work before and overnight stop working?
Old May 31, 2010 | 09:08 AM
ekplatano's Avatar
more info....
Old May 31, 2010 | 09:46 AM
Honda Bull's Avatar
Replace your coil in the distributor with a known good one (a lot of the D-series and B-series coils are interchangeable). Ignitor could be bad, as well.
Old Jun 1, 2010 | 03:59 AM
ekplatano's Avatar
[QUOTE=Honda Bull;42627657]Replace your coil in the distributor with a known good one (a lot of the D-series and B-series coils are interchangeable). Ignitor could be bad, as well.
i already did
Old Jun 1, 2010 | 04:27 AM
GhostAccord's Avatar
Did you replace the ignitor/ICM?
Save yourself some time and money buy/find a shop manual for your car. That way you can actually test these parts before needlessly replacing them. Throwing parts at the problem isn't going to help figure out what the problem is.
Test the following;
Main relay
ICM (ignition control module aka ignitor)
Coil
Plugs
Wires
Cap Rotor
Check all of your ground wires to ensure they are clean and make good contact.
Old Jun 3, 2010 | 07:42 AM
ekplatano's Avatar
tanksss
Old Jun 6, 2010 | 07:19 PM
honda-junky's Avatar
Originally Posted by ekplatano
it cranks but nothing it doest has spark
So not to be a dick, but I read your whole post and you need to be more clear:
From what you said it could be "it doesn't have spark" or it could be "it does have spark"
Which is it?
Old Jul 1, 2010 | 04:59 PM
ekplatano's Avatar
more info tttttttttt
Old Jul 2, 2010 | 12:43 AM
SiR831's Avatar
For the car to run....You need Spark @ the right time....Fuel....& compression....Give us some better info & we'll be glad to help...
Old Jul 10, 2010 | 07:33 PM
ekplatano's Avatar
Old Jul 10, 2010 | 11:50 PM
chewyv's Avatar
pm4nudes
what??? i dont understand this language...
Old Jul 10, 2010 | 11:53 PM
chewyv's Avatar
pm4nudes
how did it drive prior to this?? idle?? How many miles on it and what have you replaced??
Old Jul 11, 2010 | 06:05 AM
fcm's Avatar
fcm
Old Fart
As mentioned, not enough info, do/try these things and let use know....
1- When you turn on the ign. to run, [not start] can you hear the fuel pump prime, it should run for a few seconds?
2- Try starting the car then immediately remove a spark plug, is it wet with gas and the smell of gas or is it dry?
3- Plug the removed spark plug into it's lead and ground the plug to the engine, [any ground point] and have someone crank the engine, do you have spark, how good is the spark?
Do you have a multimeter or 12V test light? 94
OrangeTeggy
Other Make Vehicles
Dec 12, 2009 04:11 PM
siblue_gzer
Mar 9, 2006 12:49 PM
SloCrxDx91
12
Jan 22, 2006 07:21 AM
D3LSLO
Dec 15, 2003 02:06 AM
