help: i cant stop my motor from idling wrong
Old Mar 22, 2002 | 12:30 PM
topher's Avatar
New User
Default help: i cant stop my motor from idling wrong
ok
my b16a2 does NOT have a fast idle thermal valve
so thats not the problem
althought it matches the symptoms exactly as described in the following article
http://www.motor.com/MAGAZINE/Articles/042000_05.html
this is EXACTLY what my motor was doing
and I went to buy the valve
only to find that my motor did in fact NOT have a Fast Idle Thermo Valve
now my question is this
what the heck could the problem be???
Idle air controller???
I dont even know anymore!!!
Old Mar 22, 2002 | 01:34 PM
mantic6t9's Avatar
Default Re: help: i cant stop my motor from idling wrong (topher)
A faulty distributer will also cause this probem.
Old Mar 22, 2002 | 02:31 PM
ek9type-R's Avatar
try looking at the air con wires (the ones that lead to the radiator i think) on the left side of the car, coz they sometimes drop low and get cut up by the pulleys. This happened to my car and caused the revs to go up and down during idle. The mechanic said it caused the ECU to receive signals which the air con was not sending out....
Old Mar 23, 2002 | 12:27 AM
CivicEK.PDX's Avatar
Have you set the idle? There is a process to set the idle correctly. Do that and your problems solved.
Old Mar 23, 2002 | 06:17 AM
topher's Avatar
New User
Default Re: help: i cant stop my motor from idling wrong (CivicEK.PDX)
how do i set my idle?
stuckinmud
Aug 14, 2009 08:32 AM
rob260
Apr 2, 2006 08:11 AM
SOHCD16y8
Mar 5, 2006 06:47 PM
brockscivic
26
Dec 9, 2003 04:49 PM
SPEED123
Feb 18, 2003 09:03 AM
