Help!!! Got Hydrolocked!!!!
Old Feb 16, 2003 | 09:41 PM
sleeper[Xsi]'s Avatar
Default Help!!! Got Hydrolocked!!!!
Alright guys.... On friday as I got out of work it started to rain. As I got home there was a big deep puddle in the parkinglot so i slowly went through. Then some Guy in a off-road truck went through it as I was clearing it and splash alot of water to my CAI... Any tips on how to fix this or am i screwed!?!?!
Your Comments will be appreciated
Old Feb 16, 2003 | 09:47 PM
Al Bundy's Avatar
Default Re: Help!!! Got Hydrolocked!!!! (sleeper[Xsi])
Uhhhh....so what happened?
Old Feb 16, 2003 | 09:49 PM
Default Re: Help!!! Got Hydrolocked!!!! (Al Bundy)
Sorry.... My engine died and i cant get it to turn over anymore
Any tips?
[Modified by sleeper[Xsi], 6:49 AM 2/17/2003]
Old Feb 16, 2003 | 09:57 PM
Anyone??????
Even tell me im screwed if i am. I just need some help guys.
Old Feb 16, 2003 | 10:13 PM
VTECpowered's Avatar
Most likely you snaped a rod and locked the engine...
Old Feb 16, 2003 | 10:17 PM
Default Re: Help!!! Got Hydrolocked!!!! (Vtecturbocrx)
Rods seem to be in perfect shape... from what i can see....
Old Feb 16, 2003 | 10:27 PM
Kamin's Avatar
um you do know the rods are inside the engine right?
i would take it to a mechanic, asap.
Old Feb 17, 2003 | 01:06 AM
eg6sir-s's Avatar
Alright, am i screwed!?!?!
sorry to say, yes you're screwed...you'll need a new motor.
[Modified by eg6si, 2:07 AM 2/17/2003]
Old Feb 17, 2003 | 02:58 AM
SiN.DC2R's Avatar
You need to start looking for a new motor. Make sure you take a friend with you who knows about cars when buying your new motor. Good luck.
Old Feb 17, 2003 | 12:46 PM
genetsang's Avatar
drain the oil.. see if there is water in the oil. if there is water... it should look like coffee... add new oil... if it still dont start... then it might be the starter... if all that doesnt work.. take it to a mechanic... cus it definetly is something internal.. and will have to have your motor rebuilt...
Old Feb 17, 2003 | 02:19 PM
chevyalltheway's Avatar
take the sparkplugs out and try and crank the engine over if you think it is hydrolocked. if water is in the cylinders then it will just spray out the plug holes. if that is the problem you should still look over your engine and make sure nothing is damaged.
Old Feb 17, 2003 | 02:31 PM
tominos's Avatar
what rods are you looking at? i doubt that you hydrolocked, just a little splash of water on the intake? how did he splash water on it? did you have your bumper off or something? cuz he woulda splashed water on your bumper. maybe you got your ignition components wet.
Old Feb 17, 2003 | 02:36 PM
sslude's Avatar
wow,your car got hydrolocked by getting water splashed on it? talk about bad luck.
Old Feb 17, 2003 | 04:25 PM
Default Re: Help!!! Got Hydrolocked!!!! (tominos)
I got no wheel well cover... so thats how it got splashed over
[Modified by sleeper[Xsi], 1:30 AM 2/18/2003]
[Modified by sleeper[Xsi], 1:33 AM 2/18/2003]
Old Feb 17, 2003 | 04:27 PM
Default Re: Help!!! Got Hydrolocked!!!! (Kamin)
I popped open the valvecover took a gander... thnx for the advise
Old Feb 17, 2003 | 04:29 PM
Default Re: Help!!! Got Hydrolocked!!!! (chevyalltheway)
i did that and for some reason only 1 and 2 are pumpin out water while 3 and 4 isnt...... sigh....
[Modified by sleeper[Xsi], 1:38 AM 2/18/2003]
Old Feb 17, 2003 | 04:31 PM
Default Re: Help!!! Got Hydrolocked!!!! (SiN.DC2R)
I feared that.... Thnx man.
Old Feb 17, 2003 | 04:57 PM
Kamin's Avatar
you still cant see the rods if you take off the valve cover.
Old Feb 17, 2003 | 09:58 PM
MIRRAdekhtc's Avatar
well besides being hydrolocked, check your dizzy, that happened to me on my 97 civic ex, i had just gotten, had it like 2 days, stock everything, stock intake, there was a huge rain storm, went thru a big pond of water, the car died, it wouldn't start and was throwing a code, but i took the dizzy off, took it apart and there was about a tablespoon of water in it. Cleaned it, dried everything off, started right up.
Old Feb 17, 2003 | 10:06 PM
beau_safken's Avatar
Default Re: Help!!! Got Hydrolocked!!!! (MIRRAdekhtc)
Dizzy?????????????????????????????????
Old Feb 17, 2003 | 10:15 PM
EK MONEY's Avatar
Default Re: Help!!! Got Hydrolocked!!!! (beau_safken)
break it down and diagnose..
Old Feb 18, 2003 | 11:30 AM
tpr's Avatar
tpr
Dizzy = Distrubutor
Old Feb 18, 2003 | 01:58 PM
Default Re: Help!!! Got Hydrolocked!!!! (tpr)
[Insert screeching monkey sounds]
DOH!!!!!!!!!!!!!!!!!!!!
thanks...God ya think I coulda figured that out..LOL
Old Feb 19, 2003 | 09:17 AM
ITC Racer's Avatar
You say that when you pulled the spark plugs you got water out of 2 cylinders. Was there air being pushed out of the other cylinders? Do a compression test and if that is good, get the car running and change the oil a couple times.
If it will not run, you may have a spark problem.
If you do not have compression in all cylinders, then verify all the pistons are moving when the car is turned over.
Good luck
voha
Honda Civic (2001 - 2005)
Nov 28, 2006 05:51 PM
CONTROLLED CONFUSION
Nov 21, 2006 05:13 PM
crziazn
May 2, 2006 09:53 AM
