Help! Engine cuts on and off while driving. Also hard to crank when hot.
Paragraph Alert
While driving the engine will not refire after letting off the gas until you give it substantial throttle input. I have to almost put the pedal to the floor before the engine will refire and yesterday even that wouldn't restart it. I had to downshift a few gears before it would refire. The odd thing is the car will still idle decent and doesn't seem to have a big of a problem in the lower gears. I'm guessing it is somehow load based? The problem doesn't occur every day and in fact hadn't happened in a long time, but last night on the way to work it got really bad. The gauge cluster remains working during the problem.
In addition to this the car has a problem cranking while the engine is hot. This seems to be the symptoms of a bad main relay, but I'm not sure if the relay would cause the first problem.
Any ideas?
Car is a 1994 DX hatch with a turbo B18B.
CustomEJ6
15
Dec 24, 2008 11:44 AM
