brake failure
brake failure
Hello,
I am having serious brake issues....i cant get any pedal pressure....i have completely replaced the booster and master cylinder....yes...everything has been bled out properly...i was wondering if it could be a vaccum problem or something to that extent.
THIS IS THE SYMPTOMS!!
When i depress the pedal i get nothing...if you constantly jabb it gains some pressure but, when you let go it goes back to nothing...im lost please help im about to go nuts!
Re: brake failure (silverEG6)
check all ur brakelines for holes look under the car for an leaks? when u bled the brakes, did u go start from the caliper farthest from the master cylinder? u should have pressure if not are u using the right fluid? that makes a difference find out if its dot 3 or 5 good luck
jp
jp
