Help with Compressing Valve Springs
Ok guys...i feel pretty FUCKED right now
. SO i Rented two tools from two different autostores. I rented the small handheld VS compressor from auto and that didnt work. Theres def. not enough room to fit it in my H22 head. I then went to Kragen to rent there POWERBUILT tool, the BIG ARm thingy. That didnt work!! The angle on the top compressor thing is not arched enough to fit into the head. Screwed again.
My question: Do i have any other options excluding buying that over priced tool that Snapon sells? Im just a bit aggravated right now...any help from you is appreciated.
I know this may be stupid to ask, but if any one has a tool that would work, can i borrow it??? PLEASE! i live in the Los Angeles area, Baldwin Park to be specific. Just had to try.
Aight. thanks guys!
. SO i Rented two tools from two different autostores. I rented the small handheld VS compressor from auto and that didnt work. Theres def. not enough room to fit it in my H22 head. I then went to Kragen to rent there POWERBUILT tool, the BIG ARm thingy. That didnt work!! The angle on the top compressor thing is not arched enough to fit into the head. Screwed again. My question: Do i have any other options excluding buying that over priced tool that Snapon sells? Im just a bit aggravated right now...any help from you is appreciated.
Aight. thanks guys!
Here you go: http://www.thetoolwarehouse.net/shop/SP-91400.html
Same as the Snap On tool, just cheaper.
dougday84
Northwest
Jan 13, 2010 03:13 PM
b16 matt
Feb 22, 2003 11:27 AM
