Help!...Code 6...ECT...
What could I do about this?...I tried everything...Should I replace the sensor?....I tried bleeding the system out etc....The car doesnt overheat or anything just throws this code when i turn the key to the on position and it stays on....I have a turbo LS without a thermostat in a EG...Please help!
Check the wiring for that sensor. If it's OK then replace the sensor. That code isn't about the engine actually overheating, it means the ECU thinks the sensor is bad.
Could it be because I am using an OBD1 P-28 and I had my tuner modify the ECU for a NON Vtec motor?
Im running a 97 turbo LS with a P-28(Modified for non vtec) and VAFC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18PoweredCivic »</TD></TR><TR><TD CLASS="quote"> using an OBD1 P-28 and I had my tuner modify the ECU for a NON Vtec motor?
Im running a 97 turbo LS with a P-28(Modified for non vtec) and VAFC</TD></TR></TABLE>I like how you put the important information in the first post...
I don't know... I imagine the ECT sensors are the same, but I don't know what your tuner did while modifying your ECU... Then there's also the chance that the ECT sensor isn't connected to the proper terminals of the ECU.
