Help with Car not Starting
Old Jun 2, 2003 | 08:00 PM
inFamousOneSix's Avatar
Default Help with Car not Starting
Yea its a 2nd gen teg and the starter isn't turning at all. no clicks no nothing. Swapped out battery and a known workin starter, still no luck. Car is getting power. Lights, etc work. Just that starter won't turn. Quadruple checked all grounds still no luck. Any suggestions?
Old Jun 2, 2003 | 08:08 PM
JDMCivicEF9's Avatar
Default Re: Help with Car not Starting (inFamousOneSix)
I'm running into the same problem with my girlfriends car 93 Si. I did the same things you did and no start up for the car. But the funny thing is that we push start it and it starts. Still can't figure out the problem.
Old Jun 2, 2003 | 08:40 PM
poison's Avatar
The ignition switch could potentially be bad. That is what clicks and is located in the dash panel area.
Your CEL comes on and goes off after 2 seconds correct?
runitup
21
Dec 26, 2020 05:17 PM
95civlx
Jan 24, 2011 06:18 AM
95civlx
Nov 23, 2010 05:47 AM
soto2635
Jan 15, 2009 10:44 AM
92piece
Sep 21, 2008 02:19 PM
