HELP! car misfiring........
Old Mar 30, 2005 | 09:00 AM
brnyrdcmndo's Avatar
Default HELP! car misfiring........
I just installed a USDM ITR in an EK hatch. Car starts and seems to idle fine. After about five minutes or so driving, it sputters out and dies. It feels like it is misfiring. I changed the fuel pump, igntion cap & rotor, wires & plugs, timing belt and they did not fix anything. I don't currently have a CKF sensor hooked up, but I was told it would just throw a code and not hurt the performance, so I don't think this could be the problem. Any suggesstions?
Old Mar 30, 2005 | 11:06 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: HELP! car misfiring........ (brnyrdcmndo)
No codes?
Old Mar 30, 2005 | 01:23 PM
Default Re: HELP! car misfiring........ (JDM_Ej)
No codes!
Old Mar 30, 2005 | 03:05 PM
PrettyLude's Avatar
i think you are supposed to throw a code right there, unless you run an obd1 ecu, whoever told you that the ckf sensor not hooked up does not hurt performance is lying to you, unless, you run an obd1 ecu and dizzy
Old Apr 16, 2005 | 08:23 PM
JunTec's Avatar
Default Re: (PrettyLude)
same thing happend to me...so i just grounded ma tranny...and it didnt sputter n e more....you could try that...
2Point3
May 20, 2009 05:18 PM
xsi90teg
Feb 17, 2009 04:31 PM
SETI20
Aug 29, 2004 01:00 PM
Flamenco-T
Sep 8, 2002 12:05 PM
