Help... Car died on the freeway. B16 in 1st gen crx
Old Apr 18, 2003 | 01:56 PM
crx12's Avatar
Default Help... Car died on the freeway. B16 in 1st gen crx
Driving to work the other day the engine just cut out and died. While I was coasting to a stop the engine would come back to life a couple of times. I wasn't even driving it hard at the time and I didn't hear any bad sounds. Well I get out and pop the hood and the first thing I notice was the vacuum line was hanging disconnected from the manifold. This makes me think it might be the vortech FPR is broken and just dumping too much fuel. Well I hooked it back up and tried starting and adjusting the fpr and got nothing. It started a couple of times for a few seconds. THis is an just a stock B16 with some boltons. Anyway the plugs look very black and I could see sparking on cly 1 & 2 plugs but haven't taken the cap and rotor off. The swap has been runnin great for the last year so I'm puzzled. What are some other things I could check? Any ideas what may be the problem? I was thinking maybe the screw came loose on the cap causing weird sparking. I just can't figure it out.
Old Apr 18, 2003 | 03:25 PM
Russ713's Avatar
dAng!
Default Re: Help... Car died on the freeway. B16 in 1st gen crx (crx12)
check under the distributer cap first.
Old Apr 19, 2003 | 05:32 PM
crx12's Avatar
Default Re: Help... Car died on the freeway. B16 in 1st gen crx (Black Light)
Car starts now. The screw that holds the rotor on fell out and was just sitting in the cap. Jees I'm glad that's all it was.
Thanks
Old Apr 19, 2003 | 07:29 PM
Patch's Avatar
Wow, I thought I was the only one. I don't feel special anymore.
Old Apr 20, 2003 | 10:27 AM
crx12's Avatar
Default Re: Help... Car died on the freeway. B16 in 1st gen crx (CRX PAT)
Actually mine is a 1986 model. So you can still feel special.
sohcguy
Dec 20, 2006 06:52 PM
slammedef06
Apr 11, 2006 07:13 PM
drunken jdm monkey
Oct 4, 2003 10:58 PM
