help, car is bogging still
Old Jun 11, 2002 | 12:29 PM
Spike2's Avatar
Default help, car is bogging still
The motor is a stock DX motor. I have replaced the fuel pump, fuel filter, and injectors. I also replaced the TPS and map sensor. I unbolted the cat and temporarily bypassed it to see if it might have been clogged and that didnt help either. I checked the timing and it was correct.
The car drives pretty much normal when I am in first gear, but when I go into second it bogs pretty bad if I have it more than half throttle.
Anyone have any ideas at to what else could be the problem? Could the timing belt be off a couple teeth and would that cause this to happen? Anything would help me out. thanks
Old Jun 11, 2002 | 03:19 PM
salbaje's Avatar
Default Re: help, car is bogging still (Bob Ross)
plug wires??
Old Jun 11, 2002 | 03:30 PM
iwhichisme's Avatar
its probably your tps, why would you have to replace the stock unit?, could also be the map. Ive ssen both of these problems
Old Jun 11, 2002 | 09:37 PM
Spike2's Avatar
replaced the TPS b/c i thought it might have been the problem but it wasnt b/c it didnt help. I am gonna try the wires tomorrow. Any other ideas? I also read about o2 sensor but i replaced the whole header so the o2 is good on this one.
Old Jun 12, 2002 | 09:15 PM
Spike2's Avatar
up
LinkJ
Honda CR-V & Element
13
Jan 11, 2013 12:35 AM
x91crxsix
May 20, 2008 09:04 AM
boostedEBP
Jan 23, 2008 02:20 PM
goula SOS
Jul 20, 2003 08:14 PM
