HELP: cant rev past 6500>
Old Aug 12, 2003 | 01:08 PM
h23vtec_dc2's Avatar
Default HELP: cant rev past 6500>
i dropped in a b16 in a teg and for some reason it can't past 6500.. it doesnt redline, but when it goes up around 6500 it sounds like it's getting reved really high. and it does struggle around 4500-6500 and slowly stops right at 6300-6500.. what may be the problem on this?
Old Aug 12, 2003 | 06:27 PM
Default Re: HELP: cant rev past 6500> (2lazy4u)
so no one knows?
Old Aug 12, 2003 | 06:48 PM
Weston's Avatar
What year and model of Integra? What ECU are you using? Check and see if your VTEC solenoid is being activated or not.
Old Aug 13, 2003 | 01:24 PM
Default Re: HELP: cant rev past 6500> (Weston)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Weston &raquo;</TD></TR><TR><TD CLASS="quote">What year and model of Integra? What ECU are you using? Check and see if your VTEC solenoid is being activated or not.</TD></TR></TABLE>
94 gsr w/ jdm b16.. p28, vtec solenoid is good.. now what?
Old Aug 13, 2003 | 02:06 PM
allwheelerman's Avatar
see if theres any ovbious problems with the wiring, also see what the timing is set at- not likley a problem but it wouldnt hurt
Old Aug 20, 2003 | 06:06 PM
Default Re: HELP: cant rev past 6500> (allwheelerman)
there are no obvious problems with the wiring harness.. everything is plugged in correctly and no cuts or breaks in them.. and the timing is perfectly dead on straight..
can the vtec solenoid do anything to affect it like that?
Old Aug 26, 2003 | 01:45 PM
up for help
Old Aug 26, 2003 | 02:00 PM
google's Avatar
hows ur VSS. if its not working then the car will not rev past 6500.
google's Avatar
Default Re: HELP: cant rev past 6500> (1320in11)
do u have any CEL's
Old Aug 26, 2003 | 04:45 PM
eg6h8k's Avatar
p28? i though stock jdm b16 comes w. p30? well i know the 2nd gen does..that might be ur problem...unless its chipped..?
Old Aug 27, 2003 | 11:37 PM
what's a vss and cel? it's not that it redlines at 6500. it just lags and when it gets there, it struggles bad..
oh and i'm using a p72 ecu
Old Aug 28, 2003 | 12:40 AM
mmuller's Avatar
Mad Scientist
if you are using a p72 ecu, then you must be throwing codes...what are they?
Old Aug 28, 2003 | 04:37 AM
google's Avatar
Default Re: HELP: cant rev past 6500> (mmuller)
cel = check engine light, VSS = vehicle speed sensor, its on top of your tranny the ony plug there, i belive its 4 wire maybe 3.
Old Aug 29, 2003 | 08:46 AM
would the vss do that to the car? and about the check light.. it's only knock, which i know doesn't cause it to stop around that rpm.. ill see wussup with the vss tho.
Old Sep 9, 2003 | 05:37 PM
still the same crap
Old Sep 9, 2003 | 06:18 PM
zCivic's Avatar
If you have a knock sensor code (23) vtec will not engage. If you have any real codes it may keep v-tec from engaging these are the most common 17 VSS, 22 Oil pressure, 23 Knock. Also take your v-tec solinoid wire and touch it to 12volts + and see/hear if its clicking. Its like a realy so you can hear it
Old Sep 11, 2003 | 12:06 PM
Default Re: HELP: cant rev past 6500> (zCivic)
it's weird, cause when i check for codes, the check light just sits there(no blinking at all) what's going on there?
i'm thinking it's the vtec solenoid. but thanks for your help
Old Sep 11, 2003 | 12:56 PM
zCivic's Avatar
yeah if no codes it should activate. Do you have enough oil, low on oil will prevent v-tec. Or go with the prior and touch the green/white vtec sol wire to a battery + and make sure it clicks
97reddelsol
May 11, 2013 03:27 PM
jdmEJchillen
15
Apr 9, 2008 11:58 AM
ImPuLsIvE
Sep 18, 2007 08:16 PM
IhAvEaLuDe
Oct 11, 2004 09:34 PM
