B16 VTEC always engaged
Old May 4, 2013 | 07:28 PM
97reddelsol's Avatar
Default B16 VTEC always engaged
Hello everyone i have a buddy who build old school mini's and puts a B16 in them. He called me today asking for answers and i didnt really have a specific one to give him.
Its a mini with a B16 tuned on a P06 ecu.
He says vtec is always engaged no matter what rpm he is at. I said i help him and try to figure it out.
Only thoughts i had were wiring is wrong. ECU is ******* up or vtec solenoid is bad. I have an extra P28 and P72 ecu i was gonna hook up and see if it helps but not to sure what to try after that so any ideas and opinions are welcomed. When i get to the car on wednesday i will get more info. But for now that is alli have. If you need to know more please let me know and i will get it for you.
Thanks Jayden
Old May 4, 2013 | 08:46 PM
raverx3m's Avatar
Default Re: B16 VTEC always engaged
did he try unplugging it?
and how can he be sure its engaged and not some other issues?
Old May 4, 2013 | 10:27 PM
Rocket's Avatar
Good point. Unplug the connector to the solenoid and see if anything changes.
Old May 4, 2013 | 10:56 PM
raverx3m's Avatar
he might think its on all the time because engine is running hella rich or lean
or timing is incorrect or some other issues.
i dont think he knows whats goin on.
vtec needs oil pressure to engage the rocker.
and 15-30 psi in low rp, aint gonna be enough to lock vtec rocker.
he cant possibly be in vtec even if he wanted to. unless all rockers just seized suddenly
or he has the ferrera vtec roller rockers or something.
Old May 5, 2013 | 04:30 AM
SR20S13's Avatar
No you can lock VTEC in with a normal rocker setup, but I'm sure VTEC just isn't engaging so just thinks its on all .the time....so yeah unplug it and see what happens
Old May 5, 2013 | 07:40 AM
PyroProblem's Avatar
If nothing changes after unplugging the solenoid and you suspect vtec is still staying engaged, pop off the valve cover and push down on the vtec rocker/LMA to verify the rockers are not locked together.
The middle rocker should be able to move independently of the others. If it doesnt, verify the rocker arm pins are all installed correctly/not binding...
Old May 5, 2013 | 09:56 AM
n*werk's Avatar
Really op? Is there any check engine light?
Old May 5, 2013 | 06:08 PM
datbumper's Avatar
Awesome. Teach me how to do this mod!
Old May 5, 2013 | 06:29 PM
raverx3m's Avatar
Buy an ls motor. Vtec always on
Old May 5, 2013 | 07:22 PM
I am just saying what he told me. I know it sounds crazy i thought so too. I have been working on hondas for around 7 years and never heard anything of this before. Only that vtec doesnt engage. So thats why i came asking questions. And when i get to the car on thursday i will try all that you all have said.
Old May 5, 2013 | 09:53 PM
holmesnmanny's Avatar
What makes him think vtec is staying on all the time ? Has this been confirmed ?
Old May 7, 2013 | 12:38 AM
I called him today and he said it was the guy who tuned it said so.
Old May 11, 2013 | 03:27 PM
Brewbot87's Avatar
I don't see how it could be on all the time and why he would even think this...
camtoe420
Engine Management and Tuning
Nov 28, 2012 06:47 PM
gtimax
Aug 16, 2011 03:57 PM
Sean5826
Jun 18, 2008 10:17 AM
xxwhixx
Nov 7, 2005 12:23 AM
T"u"Rtle
Oct 7, 2005 12:11 PM
