HELP with camber!!!
Old May 19, 2003 | 10:23 AM
civic_tko's Avatar
Default HELP with camber!!!
I have my car lowered with Skunk2 coilovers and may camber is slightly off. I went to a local shop to get an estimate on pricing of a camber kit and install with an alignment. They quoted me $750, but this shop is known for being expensive (but at the same time they do quality work). I just don't have that much money to spend on camber correction. The kit they were going to order is the SPC Performance front and rear kits. Is there a cheaper kit or an easier way to adjust my negative camber that won't cost me out the ***? Thanks.
Old May 19, 2003 | 11:38 AM
GSpeedR's Avatar
Default Re: HELP with camber!!! (civic_tko)
If you simply want more positive camber then get the Progress kit, and spend 2 hours installing it yourself (if it's your first time). $185 shipped from http://www.autospeedracing.com about 2 years ago. Use the washer trick (search) on the rear suspension. $750 is absolutely rediculous.
Old May 20, 2003 | 01:45 PM
VTECorona's Avatar
Default Re: HELP with camber!!! (GSpeedR)
A skunk2 camber kit can be had for 189 from http://www.groupbuycenter.com right now.
airikkCRX
Feb 22, 2011 04:53 PM
Romo Pyro
Sep 26, 2010 05:22 PM
siguy9900
16
May 13, 2008 07:05 PM
hondaPINK
Suspension & Brakes
Oct 24, 2006 02:45 PM
SD_EM1
Sep 30, 2003 09:17 PM
