brake noises
Old Nov 30, 2006 | 10:17 AM
Sic_DA_Nine's Avatar
Default brake noises
sorry if this is a repost..but i cant seem to find my old thread.
recently..my front brakes have been making noises...
only when rolling..
when im off the brake pedal and rolling, it makes this screeching sound
but once i put pressure on the brake pedal, the noise goes away..
i was thinkin that i needed to change my pads and stuff...
bu can it be anything more?
i just ordered some new front rotors and brake pads...
anything else i should be informed about?
Old Nov 30, 2006 | 10:58 AM
Lan's Avatar
Lan
Default Re: brake noises (Sic_DA_Nine)
Change your pads. What you're hearing is the wear indicator.
Old Nov 30, 2006 | 11:01 AM
Default Re: brake noises (Lan)
just the pads?
can anyone confirm...?
hopefully its just the pads
Old Nov 30, 2006 | 11:02 AM
Lan's Avatar
Lan
It's just the pads. Unless you've got rotor warp or something.
Old Nov 30, 2006 | 01:37 PM
GRAF-FITI's Avatar
* B A N N E D *
+1 for the wear indicator....its always a good idea to atleast machine the rotors within spec when replacing the pads, but i would personally just buy a decent set for around 50 bucks. on a side note, i wouldn't worry too much about your rotors being warped as this condition usually results in a pulsating of the sterring wheel when the brakes are applied. since you didn't state this as an issue, your pads are the main concern but do it right and replace the rotors as well.
Old Nov 30, 2006 | 01:43 PM
GoldCoin's Avatar
my friend had a rock or something stuck in there to make a screeching noise and have the same symtoms your car has
Old Nov 30, 2006 | 02:44 PM
..::91TEG-G2::..'s Avatar
Default Re: brake noises (DC TWOin IT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC TWOin IT &raquo;</TD></TR><TR><TD CLASS="quote">my friend had a rock or something stuck in there to make a screeching noise and have the same symtoms your car has</TD></TR></TABLE>
It's been known to happen but on a rare case. For the average joe, this usually means he's hitting the metal tabs aka change pads soon indicator as every one else has been saying.
Mine was doing it one day but it was after I was parked outside for 2 weeks (driving her of course) and I thought the weather might of affected it, turns out when I took the wheels off, it was in fact the indicator piece against my rotor.
Time for some Hawk pads!
Old Nov 30, 2006 | 03:36 PM
Sam92Teg's Avatar
If you wait too long to change the pads after the wear indicator hits, you can start to wear the rotor on the backing plates, so don't wait too long or you will need new rotors if they can't be machined within specs.
Old Dec 2, 2006 | 06:46 AM
ok..i already placed my order for new rotors and pads...
will be comming dec 7th..
but unfortunately....this is the only car i got...so i gotta drive it tll the 7th...then change em out
Tenzo
Suspension & Brakes
May 13, 2012 11:03 AM
turnsignalandy
Nov 12, 2006 03:35 AM
YodajdmEK4
Jul 23, 2005 05:33 PM
faSHOwidIT
Apr 18, 2005 02:06 AM
functionFiRst
Oct 2, 2002 09:49 PM
