HELP with Brake problem
Old Feb 11, 2004 | 08:17 AM
O3DigitalBath's Avatar
Default HELP with Brake problem
I was putting new pads and rotors on my car and I had someone pump the brakes while the caliper was off and not even thinking that they were pumping the brakes i started to look for a tool.....well when i looked back to the caliper the brake piston is WAY out, i was able to push it back in some of the way but I can't seem to get it all the way back to where its supposed to go...anyone have any ideas?
Old Feb 11, 2004 | 08:23 AM
mmuller's Avatar
Mad Scientist
Default Re: HELP with Brake problem (O3DigitalBath)
Why would you have someone pump the brakes?
Well you prolly unseated he piston. If you cant get it back in you gonna have to take the caliper apart and put it back together
Old Feb 11, 2004 | 08:37 AM
1BadCvC's Avatar
Default Re: HELP with Brake problem (mmuller)
we had that happen on my buddys Trans am, we just completely took the caliper off and beat both the pistons back, to make it easier you can also buy a tool from any car parts place for like 2 bucks that will push them back. Or you gon have to do what mmuller said
Old Feb 11, 2004 | 09:04 AM
haha, tried the tool...it broke
Old Feb 11, 2004 | 09:14 AM
1BadCvC's Avatar
Default Re: (O3DigitalBath)
lol, dam, gon have to rebuilt it then prolly...
Old Feb 11, 2004 | 09:20 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">Why would you have someone pump the brakes?
Well you prolly unseated he piston. If you cant get it back in you gonna have to take the caliper apart and put it back together</TD></TR></TABLE>Since you tried to push it back in, you probably tore the piston seal. Get a rebuild kit so you have new seals to put in.
Old Feb 11, 2004 | 01:24 PM
I got the piston back in finally...is there anything i can use just for a few days to seal the piston untill i have time to just replace this POS?
like is there anything i can just put around the edge of it?
Old Feb 11, 2004 | 02:38 PM
MightyMouseTech's Avatar
Put around the edge of it?
You do realize that a brake caliper can operate as high as 2000 PSI!!!!!!!!!
Never screw around with your brakes....
Old Feb 11, 2004 | 03:21 PM
yea i see it now...a buddy of mine came over and helped explain it...I was under the impresstion that the seal needed something to help stay...
Old Feb 11, 2004 | 05:55 PM
Sobe_Death's Avatar
wtf yo! you stole my avatar!!!
ksweetland
Suspension & Brakes
12
May 18, 2012 03:19 AM
red91efhatch
Feb 26, 2009 10:06 PM
Flux
Sep 21, 2005 03:39 PM
integrakilla
12
May 5, 2004 05:08 AM
JDM TypeR 307
Feb 27, 2004 06:07 PM
