HELP!!..battery drainage problem...
Old Mar 8, 2004 | 09:53 AM
esoterEK..'s Avatar
Default HELP!!..battery drainage problem...
https://honda-tech.com/zerothread?id=792144
Old Mar 8, 2004 | 10:58 AM
JimBlake's Avatar
Default Re: HELP!!..battery drainage problem... (EGkwazhimoto)
Sounds like you pulled the battery cable, then the engine died. That normally means your alternator isn't working. So was it a new alternator or a new battery. If it's a new battery, I guess you just proved that the problem was your alternator all along...
BTW, that's kind of a dangerous way to check it. Back in the day, before cars had computers, it was OK. But pulling the battery cables makes voltage spikes that SOMETIMES can fry your ECU.
97_hatch
May 21, 2008 02:38 PM
hondastrtracr
16
Jan 27, 2008 09:16 PM
Syndacate
Aug 14, 2007 05:10 PM
ID_ten_T
Nov 2, 2004 11:24 PM
BlowOff
Jun 11, 2002 07:08 PM
