help!!!!
Old Jan 11, 2003 | 06:21 PM
eccentric.ek's Avatar
Default help!!!!
i have a 90 accord dx, i turned off my car, went to the atm, turned on my car, and as i was leaving the parking lot my car just shut off in the middle of the street, so i have it towed home, check it out, its not getting any spark, so i look in my chiltons or what ever its called, and follow the steps to check to see if its the coil, or ignitor, both tests come up good, i change the cap and rotor just because its about that time, and new spark plugs, test it out and i still get no spark, anyone that can help me on this???? maybe ecu problem or what i really have no idea, so if anyone can help please do. thanks
Old Jan 11, 2003 | 06:42 PM
rated_r's Avatar
Default Re: help!!!! (redUSDMhb)
do a pressure test... See if u are getting any fuel.. Or check your timing belt
Old Jan 11, 2003 | 07:47 PM
tominos's Avatar
your battery is good right.
Old Jan 12, 2003 | 05:27 PM
Default Re: help!!!! (tominos)
ya battery is fine
Old Jan 12, 2003 | 05:35 PM
poison's Avatar
Is your motor or tranny grounded?
Also, just making sure you are checking spark right....how are you checking for spark?
Old Jan 12, 2003 | 05:41 PM
Default Re: help!!!! (poison)
ya they are grounded, checking spark by taking out one of the spark plugs and putting it in the cable and putting it up against the block and seeing if any spark is going on
Old Jan 12, 2003 | 07:03 PM
Nizzy's Avatar
could it be your alternator?
Old Jan 12, 2003 | 09:47 PM
poison's Avatar
stick it on the front radiator support to see if you get spark.
Old Jan 12, 2003 | 10:20 PM
Usdm1's Avatar
Take off your Distributer cap and check the ignitor and coil .
Hondas are well known for frying the ignitor .
dboz3403
Sep 20, 2007 10:25 PM
ef2 from hell
Nov 25, 2006 03:07 PM
ek_chris
Nov 5, 2006 07:54 AM
riceboyEFsi
Mar 3, 2003 09:00 AM
