Help!
Old Jan 10, 2003 | 05:38 PM
SupaFly_Honda's Avatar
Default Help!
My 94 cx won't start. Whenever I turn the key into "ON" not all the lights would led up like a normal car would. Instead only the "Battery" and "SRS" lights will led, after the six seconds SRS goes off, but the Battery remains. All This happened after I cut and pulled some extra speaker, amps, and alarm wires that came with the car when I bought it. Help!
Old Jan 10, 2003 | 05:40 PM
YeuEmMaiMai's Avatar
Default Re: Help! (SupaFly_Honda)
humm I would retrace all of your steps to make sure you did not accidently disconnect something else that is vital to your car running (which you did based upon what you have described)
Old Jan 10, 2003 | 11:09 PM
Shawn C's Avatar
In The Garage
Default Re: Help! (YeuEmMaiMai)
did you try testing the battery with a digital multimeter (or voltmeter)? if the amp power wire grounded out during the wire removal, it couldve drained the batt some. sounds like that to me, or the alarm wiring could definitely mess with the car starting.
[Modified by 22lbGS-R, 8:11 AM 1/11/2003]
Old Jan 11, 2003 | 04:05 AM
Default Re: Help! (22lbGS-R)
I'll check the battery today. If the disconnection of the alarm smote my igniton, what can I do to get it back? And here is some other stuff I forgot to mention with the above. My headlights and hazard will turn on, but the turn signal wont signal, also the car stereo won't play.
thewrai6th
Jul 19, 2013 06:25 PM
ntoxicatedtigah
11
May 4, 2009 10:54 AM
dohcvtak
Audio / Security / Video
Jan 31, 2009 09:26 PM
clean_eg
Aug 14, 2003 11:23 AM
clean_eg
Aug 13, 2003 09:07 PM
